OEM OR Front Recovery Hook Hardware
Discussion in '2nd Gen. Tacomas (2005-2015)' started by slossboss, Aug 3, 2024.
  1. Aug 3, 2024 at 3:00 PM
    slossboss
    slossboss [OP] Well-Known Member
    Troy
    FL
    2013 TRD Sport 4x4 Nautical Blue Metallic
    Hey y’all.
    Recently acquired a OEM front recovery hook. I took some advice from the forum on what hardware I needed and I’m concerned the hardware is too short. See below. I count 5-6 threads exposed that would attach to frame, but given the forces involved it just looks wrong.
    Hardware is: 17mm, m 12x1.25, flange bolt, Steel Class 10.9 Zinc x 40mm
    TIA
  2. Aug 3, 2024 at 3:04 PM
    C-Rok275
    C-Rok275 Well-Known Member
    2017 TRD Pro
    6112/5160s with Icon stage 2 leaf’s.
    I believe the correct bolts are 60mm long, so about 2-3/8” long. Measure from the underside of the head, not the top.
    slossboss[OP] likes this.
  3. Aug 3, 2024 at 3:11 PM
    slossboss
    Troy
    FL
    That seems more in the ball park. 40mm seems appropriate for the standard stock loop maybe. The OEM recovery hook is thicker so I must’ve misunderstood someone else’s previous reply to a separate thread.
    Good thing I can hoard this hardware indefinitely until I need it for some random thing :p
  4. Aug 3, 2024 at 3:42 PM
    slossboss
    Troy
    FL
  5. Aug 3, 2024 at 4:18 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Yes, too short. A good rule of thumb for thread engagement is 1.5 X diameter.
  6. Aug 3, 2024 at 5:51 PM
    TacoTuesday1
    FL
    Would not be running that hook.
    Look up in parts catalog. Or measure.
  7. Aug 3, 2024 at 8:41 PM
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    Thank you for posting. Is that a 12mm bolt that uses a 17mm socket?
  8. Aug 4, 2024 at 5:55 AM
    slossboss
    Troy
    FL
    17mm socket yes, m12 refers to 12mm thread diameter
  9. Aug 4, 2024 at 3:47 PM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    Those bolts go up into some nuts tack welded onto the inside of the x-member. Use a bent wire to fish up inside the open hole and find the back of the nut. Your chosen screws should stick out of the hook casting for that distance so you've got all of the engagement possible.
    BKinzey likes this.
