OEM OR wheel and tire weight?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JAL, Apr 27, 2018.
  1. Apr 27, 2018 at 10:40 AM
    JAL
    JAL [OP] Well-Known Member
    Mississippi
    96 Tacoma Access Cab (sold) now 2018 Tacoma DCSB 4X4 OR (traded). Current 2022 TRD DCSB OR Celestial Silver
    RCI Sliders and mostly stock.
    Did a search but found nothing that verified the Tacoma OEM OR Goodyear Wrangler Adventure with Kevlar wheel and tire weight, has anybody weighed them?
    I'm looking to upgrade these tires but want to stay with similar weight for MPG considerations.
    I can search the tire and find its weight but haven't found the actual wheels weight.
    265/70R16, 112T SL, No 3PMSF, OE Tread Design 640 A B , 2,469 lbs., 51 psi 11/32", 35 lbs. 7-9" 8", 10.7" 8", 30.6", 682 CA
    But looking for the total for this comparison, thanks ahead of time.
  2. Apr 27, 2018 at 10:44 AM
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    Just so you know, comparing total weight will not yield accurate results becaise it also matters where the weight is located for rotational inertia.
    Tire weight is more critical as its radious is larger than the wheels. Just something to consider.
    TacoTim85 likes this.
  3. Apr 27, 2018 at 11:04 AM
    JAL
    Mississippi
    Yes sir, understand. So in what way would the weight be distributed to make the most difference in maintaining best fuel economy and offload capability?
  4. Apr 27, 2018 at 7:09 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    There's a lot that goes into tire design. To keep it relatively simple for trucks, because the sidewall is so tall, the tires impact performance more than wheels. For best fuel economy you want the lightest stock size tire(most important) with the lowest rolling resistance(less important). The larger the tire, the heavier it becomes and the larger the radius (moment of inertia) which makes the performance impact (mpg, 0-60, etc) exponentially worse.
    For off road you want ground clearance and max traction(typically high rolling resistance), so you cant realistically have both mpg and a great tire on dirt. A good compromise seems to be a 265/75r16 in an AT tire that is P or LT rated. Avoid C or E load ratings unless you are a serious rock crawler and feel like you need an extra heavy sidewall.
