OEM parts not available from Toyota?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Travlr, Mar 8, 2021.
  1. Mar 8, 2021 at 8:16 AM
    Travlr
    Travlr [OP] Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    It appears that if you need to replace the $20-30 driveshaft boot on a 2nd Gen Tacoma, at least from Toyota... you will need to buy the entire driveshaft for about $900.
    Any ideas?
    Has anyone used the Spicer #211932X boot kit?
    From what I can see it looks identical to the original Toyota boot as it is illustrated, but they don't list the ID for both ends or the overall length.
    The original boot is four ribs/five if you count the bigger end, 4 3/4" long, and the ID is 1 3/4" on one end and 1 1/8" on the other.
    https://www.amazon.com/gp/product/B...3&pd_rd_w=K1j52&pd_rd_wg=KUHWB&ref_=pd_gw_unk
    EDIT: I installed the Spicer #211932X boot kit and it fit perfectly.
  2. Mar 8, 2021 at 9:11 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  3. Mar 8, 2021 at 9:11 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  4. Mar 8, 2021 at 9:13 AM
    Travlr
    Middle'a Utah
    Island Cruiser likes this.
  5. Mar 8, 2021 at 9:21 AM
    Travlr
    Middle'a Utah
    It appears that there may be another boot that might work.
    Spicer #211916X is the same ID as #211932X at both ends... 1.67" and 1.14" respectively. #211932X is longer, being 5.03 inches compared to #211916X at 4.07 inches long.
    I measure the original boot, at least on the shaft, as 1.102" and 1.693" and 4.75" long.
  6. Mar 8, 2021 at 9:24 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    You take a pic of where it is on your truck as the only boots I have ever seen are inner and outer cv boots
  7. Mar 8, 2021 at 9:26 AM
    Travlr
    Middle'a Utah
    It's on the slip joint... on the rear drive shaft. Right behind the carrier bearing.
  8. Mar 8, 2021 at 9:27 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Hmmmmmmmmmmmmm never noticed that
  9. Mar 8, 2021 at 9:23 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    DANA SPICER 211932X
    • Rubber Dust Boot for spline and slip style driveshaft
      • Designed for the large end to fit onto the slip yoke and the small end to fit onto the smooth shank of the 1 3/8 inch spline
    • Comes with two clamps to firmly attach boot to slip yoke and to spline shaft
    • Normally found on 1210, 1310 and 1330 series driveshafts
    • Fits 1 3/8 inch diameter splines
    • LARGE END DIAMETER = 1.670 inches
    • SMALL END DIAMETER = 1.140 inches
    • BOOT LENGTH = 5.030 inches
    • 4 Bellows
    See SPICER 211916X if you need a boot one inch SHORTER
  10. Mar 11, 2021 at 6:55 AM
    Travlr
    Middle'a Utah
    Yup, that's the one I mentioned in the first post. Have you used it? Does it fit? Actual experience?
    EDIT: I installed it and it fits perfectly.
  11. Mar 11, 2021 at 7:17 AM
    blu92in99
    blu92in99 Hates everyone, equally
    Elk Grove, Ca
    Rebuilt both driveshafts on mine with Spicer/Dana parts including the slip yoke boot. Worked fine, everything fit as it should. Wasn't surprised by it though, Spicer/Dana makes those driveshafts for Toyota.
    Travlr[OP] likes this.
  12. Mar 11, 2021 at 7:50 AM
    gearcruncher
    Canadain bumper technician
