OEM Push Button Switch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RDNK TAZ, Jul 5, 2014.
  1. Jul 5, 2014 at 9:39 PM
    RDNK TAZ
    RDNK TAZ [OP] Well-Known Member
    Chad
    Marion, SC
    '11 Silver Streak Mica DCSB TRD 2x4
    I need to add some warning lights to my truck. I want to keep a stock look and have been looking for a place to get either OEM or aftermarket push button switches like I already have. Does anyone know of some good places to try? I'm at a dead end. I also need a three way switch for my siren. That one I know won't be like stock but I can live with that.
  2. Jul 5, 2014 at 9:42 PM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    Search on here. There is a guy that has some available.
  3. Jul 5, 2014 at 9:43 PM
    KAHolt
    KAHolt Well-Known Member
    Kris
    Roseville, California
    14' TRD Double-Cab Short Bed
    Pro-Comp 3" Lift (ES6000 on Front- ES9000 on Rear w/ 1.5 AAL) 42" Roof Mounted Light Bar
    Ebay, check out the seller aironboard. That's why I got my oem switches (modified of course with different sayings)
  4. Jul 8, 2014 at 5:38 PM
    RDNK TAZ
    Chad
    Marion, SC
    I checked on ebay and couldn't find aironboard. Do you have a link?
  5. Jul 8, 2014 at 8:39 PM
    treaddy
    treaddy Well-Known Member
    alberta
    08' oft-road, 3" ^
    3" OME, ARB front, W8000, lil"mods, ongoing,,,
    Toyota of Dallas sells oem switches, trd parts i believe, use either taco or fj switches
    Cheers,
  6. Jul 9, 2014 at 5:00 AM
    txjoe
    txjoe New Member
  7. Jul 9, 2014 at 8:14 PM
    RDNK TAZ
    Chad
    Marion, SC
  8. Aug 14, 2014 at 7:33 AM
    sofiasdad11
    sofiasdad11 Reads more than posts
    Near the Windy City, but in the country
    2011 BLACK 4X4 DCLB TRD SPORT
    Flux capacitor (2nd gen version), toytec ultimate liftkit, amp research powersteps, custom katzkin heated leather incl. console cover, retraxpro retractable bed cover, earnhardt jr. cannons@18x9(summer),ballistic jesters@18x9 (winter),285/60/18 nitto grapplers, bodymatched bushwackers, the original Homertaco full satoshi " raptor" grill, viper 5704 remote/smart-start/alarm w/viper cellulor app, ravelco anti-theft device, ipcw tails, redline hoodstruts, oem roof rack, led maps/dome, backup light mod, swingcase storage box, jl audio stealthbox and amps,focal drivers,alpine carplay unit, pop&lock premium handle, seatbelt chime disabled, tailgate hoseclamp mod, rich evans caliper covers, weathertech digitalfit mats, flyzeye V2W,oem bedmat, salex console organizer,speeddawg shiftknob
  9. Aug 14, 2014 at 8:32 AM
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    Anyone know a source for a switch for the center console (with the USB/Aux input) on the 2012+ trucks?
  10. Aug 14, 2014 at 8:35 AM
    diemaco
    diemaco Active Member
    Ontario
    ICON Stage 3 TRD CAI
    On board air has the 2012 switches as well
    Charger92 likes this.
  11. Aug 14, 2014 at 8:40 AM
    Capt. Obvious
    Darrick
    Gig Harbor
    '12 DCLB TRD
    Maybe I didn't look hard enough. All the switches I looked at said they only fit on the left side of the dash, not in the center console spots.
  12. Aug 14, 2014 at 8:46 AM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    That may be a bit tougher to source because the blanks (if you pop them out) only fit into one dedicated hole. Each blank has alignment tabs in a different location so they don't interchange. Any switches made to fit in those holes would have to be dedicated to one hole, or would have to be such a sloppy fit that they wouldn't look OEM so as to fit into any of the three open spots, or would require filing to fit.
    At any rate I have not seen switches that replace those panels.
  13. Aug 14, 2014 at 8:47 AM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    I like the switch from the 1st gen. Easy to install (taper) in the slot of 2nd gen and easy to connect. + less expensive.
  14. Aug 24, 2014 at 7:58 PM
    TacomaD4D
    TacomaD4D Well-Known Member
    Central TX
    2014 Tacoma TRD D-4D
    DieselToys engine swap Lots more to come….
    I think I might have found some 12+ center switches that will work. This company shows that they will ship internationally!! I am going to attempt to confirm they will fit before ordering. The sizes appear to be correct vs the air on-board center switch I ordered last month. Air on board has been sold out ever since my last order...
    http://www.customrockers.com.au/epag...%20SWITCHES%22
  15. Aug 25, 2014 at 7:00 AM
    bcubed
    bcubed Well-Known Member
    Brent
    Calgary AB
    Just ordered mine from AOB. I have a zombie switch but don't want to trim any parts of a brand new vehicle to make them fit
