OEM radio change out
Discussion in 'Technical Chat' started by Bobn, Jun 28, 2018.
  1. Jun 28, 2018 at 8:54 AM
    Bobn
    Bobn [OP] Member
    Bob
    2009 Taco access cab 2x4
    none
    I think the radio in all 2009 Tacoma's are screw up. My question is: if I buy a radio on ebay will I need to get a theft lock code from the dealer if I change it out myself, and how hard is it to get a theft lock code from the dealer if so ?
  2. Jun 28, 2018 at 5:58 PM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    If you are not happy with the oem radio, why not put an aftermarket radio in?
    My '09 radio went south a few months ago and I put a single din Pioneer in. Works great. I sacrificed the steering wheel controls, but the radio is easy to reach, so no loss there. Actually gained a few benefits--the only one I use is the usb input.
  3. Jun 29, 2018 at 10:44 AM
    Bobn
    Bobn [OP] Member
    Bob
    none
    I guess I wasn't sure of the trim fitting well and the convenience of the plug and play aspect.
  4. Jun 29, 2018 at 10:44 AM
    Bobn
    Bobn [OP] Member
    Bob
    none
    Can I just buy one at Walmart and install it myself?
  5. Jun 30, 2018 at 8:32 AM
    azreb
    azreb Geezer
    TN
    Installation is easy. If you go with a single din, you will need a different piece for the dash. Amazon has one for a few bucks. If you need the steering wheel controls, it gets a bit more complicated with a non-oem unit.
  6. Jun 30, 2018 at 1:03 PM
    kgw
    kgw Well-Known Member
    kgw
    SoCal
    99 PreRunner
    140 amp alternator, Big 3 upgrade, Ultimate Headlight Mod, Trans Cooler
    Crutchfield has it all! Prebuilt harness for plugging right into the oem wiring...
