oem radio has no sound suddenly
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cropduster78, Sep 2, 2025 at 12:59 PM.
  1. Sep 2, 2025 at 12:59 PM
    cropduster78
    cropduster78 [OP] Well-Known Member
    NW CT
    '17 DCLB SR5 White
    OV-TUNE 2.0, ADDED/REMOVED STUFF
    Afternoon everyone.........:cool:
    Last week I had an issue with my '17. 103k on it.
    I was on my way home listening to music on my factory radio with the aux/ usb port.
    To my knowledge my truck is bone stock electrically nothing cut or messed with.
    I turned my truck off went into the store BS'd with a friend came back 15 minutes later started the truck up and suddenly had no audio coming from the radio.
    Strange thing is everything works on the unit except no audio and no beep when pressing buttons on the radio.
    Any suggestions would be appreciated.
    Thanks B
    (note I did look at fuses nothing seemed out of the ordinary and I have no lights etc happening)
  2. Sep 2, 2025 at 1:56 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Try unhooking the Negative battery cable for 30 minutes.
    You can also check if newer Entune firmware is available and might fix your issue.
    https://www.toyota.com/firmware-updates
  3. Sep 2, 2025 at 2:05 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Try different functions - unpair Bluetooth, switch to FM radio. Make sure volume isn't turned down on your phone and on the head unit.
    23MGM likes this.
  4. Sep 2, 2025 at 10:14 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Ain't nuttin worth listenin to on the radio anyway.
    kahanabob likes this.
  5. Sep 3, 2025 at 2:49 AM
    cropduster78
    NW CT
    '17 DCLB SR5 White
    Morning and thanks for the replies.
    I did try removing the negative terminal unfortunately no change, and switching between all the different functions worked fine just no audio from anything. (Speakers or beeps when switching functions)
    Like I said I went from playing some Disturbed:rolleyes:....turned off the truck.....20 min later went to drive home,no audio smh.....
    Sounds like a short somewhere or maybe a connection got loose?
    I need to see about the firmware update.
    Anybody know the functionality of the "short pin" I think it's called in the fuse box?
    I was going to replace that before I have the dealer see what they can figure out.
    It's in-between the 2 radio fuses, the thing looks beat.
    I'll see my dealer after work and swap out that short pin.
  6. Sep 3, 2025 at 3:35 AM
    Archimedes
    Archimedes Demanufacturer
    Outside the stupid part of Vermont
    23 DCSB TRD OR MGM
    Full-on degenerate heavy metal banjo music
    Ironically, it didn't happen to be their version of Sound Of Silence now did it?
    (sorry couldn't resist... or help haha)
  7. Sep 3, 2025 at 8:57 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    The SHORT pin is removed for shipping from the factory, it turns off most unnecessary features. No idea what 'beat" means. If that were your problem a lot more problems would show themselves. See the attachments: Power Source page 3 shows the "Shorting Pin". Fuse list will show what all the fuses are for.
  8. Sep 4, 2025 at 4:23 AM
    cropduster78
    NW CT
    '17 DCLB SR5 White
    The short pin looked badly discolored possibly damaged.
    I swapped it out for a new one and nothing changed.
    I'll have to bring it to the dealer to diagnose.
    Hopefully it's not too costly.......:fingerscrossed:
  9. Sep 4, 2025 at 5:10 AM
    Clearwater Bill
    Billy
    Largo Florida
    I'd pull a door panel and test a speaker with another audio source. If the speakers are good, and nothing has been messed with in the dash, it would seem there is a headunit problem.
    If that needs replacing, you might as well go aftermarket. You can get more, better, for less than OE. Especially from a dealer.
    I've even bought used OE on eBay at bargain prices for other marques when my goal was to maintain originality
  10. Sep 4, 2025 at 6:48 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Used OE units I have seen for as low as $100.
  11. Sep 4, 2025 at 7:52 AM
    cropduster78
    NW CT
    '17 DCLB SR5 White
    Agreed on checking the head unit next.
    For my needs the oem is good as is.
    Any idea how much of a PITA it is to remove the radio?
    I'll YT it later thanks.
    Just hoping I don't have another harness issue from Mickey or Minnie.........:mad:
  12. Sep 4, 2025 at 9:48 AM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Pulling the head unit is pretty cake. Rip the trim off and 4 screws
