OEM Radio Turns Off...?
Discussion in 'Audio & Video' started by K Williams, Feb 20, 2015.
  1. Feb 20, 2015 at 10:37 AM
    K Williams
    K Williams [OP] Well-Known Member
    Long Island, NY
    2011 TRD Off Road V6 MT
    Banks Monster Exhaust URD Stage II Clutch
    The OEM radio in my '11 Access Cab turns off by itself? Any idea on what's making that happen?
  2. Feb 20, 2015 at 10:48 AM
    cgnsa
    cgnsa Well-Known Member
    Cameron
    San Antonio, TX
    2019 Toyota Tacoma TRD Sport 4x4 Quicksand
    Mine does this as well. Its not very often, maybe once a month or less.. But I have no idea why. I thought I was the only one that had this problem. It is kind of annoying. It seems to happen in the heat. I live in Texas, so it can get a little hot.. Don't know if there is any correlation though.
  3. Feb 20, 2015 at 10:52 AM
    K Williams
    Long Island, NY
    Mine happens in any temperature...
  4. Feb 20, 2015 at 10:55 AM
    A3umph
    A3umph Well-Known Member
    outside of KCMO
    '12 Tacoma Access Cab TRD OR
    The one in my 12 doesn't turn off but the screen goes blank and no controls on the radio will work but the steering wheel controls still do. (volume, input, track) This started right after the 36000 mile warranty ran out, just over one year old, it only seems to do it when it is very cold outside. Sometimes the screen will come back on if I touch a button on the radio itself. Drives me batty but since the steering wheel controls work I just let it play out.
  5. Feb 20, 2015 at 10:58 AM
    medic2230
    Murph
    Bama! Roll Tide
    If you're still under warranty take it in and have them replace it. Quite a few on here have done that. I just replaced the HU with a Kenwood. Mine had only done it once or twice.
  6. Feb 20, 2015 at 1:53 PM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    The radio in my 2009 Access Cab started doing that when it was less than a year old. And sometimes the radio would stay on, but the radio illumination would go out (it would go dark). I had it replaced under the factory warranty. About a year ago the replacement radio started doing the same thing. I replaced it with a JVC and have no regrets.
  7. Feb 20, 2015 at 5:30 PM
    K Williams
    Long Island, NY
    If I replace the head unit, will the steering wheel controls still work with it?
  8. Feb 20, 2015 at 5:31 PM
    K Williams
    Long Island, NY
    Which Kenwood unit did you use?
  9. Feb 21, 2015 at 5:34 AM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    My truck didn't have steering wheel controls, but Crutchfield (and others) have adapter harnesses so that you can connect those to your aftermarket stereo. The unit I installed was a JVC KW-V30BT, and I added a small Kenwood KSC-SW11 sub a couple of weeks ago.
  10. Feb 21, 2015 at 9:14 PM
    JPS11
    JPS11 Active Member
    Melbourne, FL
    2011 Prerunner DC TRD OR Black
    My 2011 did that also but I had it replaced under warranty and it hasn't done it since.
  11. Feb 22, 2015 at 9:52 AM
    K Williams
    Long Island, NY
  12. Feb 22, 2015 at 9:54 AM
    medic2230
    Murph
    Bama! Roll Tide
    DDX-470
  13. Feb 22, 2015 at 1:06 PM
    swamp rat
    swamp rat Well-Known Member
    augusta ga we call "discusta"
    09 dbl cab sr5
    westin bull bar w/ driving lights
    my oem radio volume control on the steering wheel &the knob will stop working & I loose the illumination ,if I turn it off & turn it back on again it will work just fine. Anyone else have similar problems as this ?
  14. Feb 23, 2015 at 6:20 AM
    Apricotshot
    Apricotshot Well-Known Member
    Henry
    Tampa, FL
    TRD Sport
    TRD CAI
    My OEM JBL head unit has been doing this for a few years now. Last month the woofer stopped working. Think its time to upgrade the head unit and the woofer. But with 72k miles on it I think it may be a waste of money.
  15. Aug 18, 2015 at 10:16 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    Mine just started doing this as well. 2010 Tacoma not jbl. It will also turn off if I push the plastic above the number two preset. Is there a fix or should I start saving for a new double din.
  16. Aug 20, 2015 at 8:23 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Seems to be a Toyota idiosyncrasy. Even my 1984 4runner did this. I think I had a Blaupunkt unit, and then a Kenwood. Both radios did the same thing. It was usually triggered by going over a pot-hole or something. Never could figure it out. Just put up with it. My Taco doesn't seem to be doing it, though.
