OEM Rear Bumper Alignment
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rooster32, Aug 17, 2017.
  1. Sep 25, 2017 at 6:54 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Damn,: I was right! They really need to rethink their process if they care about the misalignment.
    PanzerDivisionBlack likes this.
  2. Sep 26, 2017 at 10:35 AM
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
    We visited the BMW factory in Regensberg and the process was the same. However a tech goes over the car at the end and takes care of these issues, so it's not the process, but quality control.
  3. Oct 22, 2017 at 8:47 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    I'll bite! I am from Missouri after all...
  4. Oct 23, 2017 at 5:24 PM
    rsimi72
    rsimi72 Well-Known Member
    PNW
    2020 Tacoma SR5 Access Cab
  5. Oct 23, 2017 at 8:01 PM
    CaptainBart45
    Bart
    Work in progress...
    rsimi72[QUOTED] likes this.
  6. Oct 23, 2017 at 8:12 PM
    Gerrrr
    Gerrrr Well-Known Member
    Jeremy
    Ottawa, Canada
    2017 Blazing Blue Metallic (Limited 2013 Silver Streak DC Auto - Retired)
    Starting over.......
    I think Toyota is making everything crooked as a design feature so it is harder for police radars to pick up, think of the angular shape of a stealth aircraft ........... they just don't know how to market this feature yet, it will be a surprise for 2019 rather than something useful like Apple Car play.
  7. Mar 28, 2018 at 4:38 AM
    ejewels
    ejewels Well-Known Member
    CT
    2018 MGM TRD OR 4x4 DCSB
    6112/5160/Dakars/Pro Tacoma Wheels
    Might still not be fresh in your head, but can you or someone refer to me to these detailed instructions? So far I only found a video on taking off the entire bumper which seems like a huge PITA!
  8. Mar 28, 2018 at 2:11 PM
    rsimi72
    PNW
    The write-up below is pretty much what I followed. I found it really helpful to get the step by step instructions. The video link below is also helpful for a good visual demo. I stopped short of taking the end caps off as that is not needed to align the bumper. I did find it necessary to loosen and adjust both sides a little to get them even. There is so little room to play with in terms of adjustment that moving both sides a bit was necessary for me. Also, when popping the black step off, you can release the row of clips from below only for the side of the step nearest the tailgate/bed. The row of clips farthest to the rear are just pulled up/out with some force. It takes a bit. You could possibly pry with a trim tool or screw driver, but I was able to pull free with my hands. It might be helpful to know that the clips are the same on either side, so you'll know what you're dealing with once you take a look from below. You'll be so satisfied when you're done! Good luck.
    https://www.tacomaworld.com/threads/16-tacoma-bumper-cap-removal.404082/page-5#post-13263852
    https://youtu.be/xKhcomDLQmE
    ns3v3n and shakerhood like this.
  9. Mar 28, 2018 at 4:46 PM
    ejewels
    CT
    Thanks man. You say little adjustment... looking at my pics is there enough adjustment to fix/align it? I prob will take it to dealer soon and have them do it. We shouldn’t have to do this if under warranty on a brand new truck. It’s on those F’rs as far as I’m concerned. Also, was your bed ok?
  10. Mar 28, 2018 at 5:49 PM
    JimmySport
    JimmySport Well-Known Member
    I just did this myself to mine this past weekend. its not too hard, you just have to be careful. I broke a retainer clip to one of back up sensors and turns out you can't just buy the retainer, you have to buy the whole damn sensor if you get it from the dealer. very costly for sure, but Amazon sells a Tundra sensor that is exactly the same and comes with the retainer for $20, so I just bought one of those tonight and will use the retainer ring and hold onto the sensor for future use if need be.
    I agree the dealer should fix this issue but my dealer walked the lot and said and I quote "all the Tacoma's on our lot are like this, they have to be this way because the gas tank is on the driver's side". which is total bullshit! mine was off a full 1/2" one side to the other. loosened up the bumper and adjusted and now it sits perfectly even on each side. and I am glad I did it myself. I got to learn how to do something new and working on my own truck is always a good thing.
    TacoTim85 likes this.
  11. Mar 28, 2018 at 7:03 PM
    ejewels
    CT
    Just seems like a huge pain. Did you have a lot of adjustability to align it all? Mine is like yours about a half inch off. Do you have to fully remove the bumper, or just take the top black piece off and loosen and adjust?
    I don’t think I have these sensors... I don’t have the technology package... but not sure
    And what does the bumper have anything to do with the gas tank! Lol
  12. Mar 28, 2018 at 7:09 PM
    ejewels
    CT
    Why would you have to disconnect wiring and pop out license plate lights if only loosening things up to adjust alignment?
  13. Mar 28, 2018 at 7:12 PM
    trazerr
    trazerr Well-Known Member
    Oregon
    2024 Tundra Plat 4x4 LB (prev 2018 DCLB SR5 4x4 and 1996 AC LX 4x4 5sp)
    You have to take off the black plastic cap (what you step on) to loosen the bolts to adjust the bumper. The license plates lights and tow hookup attach to that black plastic cap. Got to pop them out and disconnect them to remove the cap. I used a big flat head screw driver to push the tab in to remove those items. Once you figure out where to push on them (took me a minute) they popped right out.
    rsimi72 likes this.
  14. Mar 28, 2018 at 7:14 PM
    JimmySport
    yes there is enough adjustment to get it right. you have to actually move both sides though. I had to move one side in 1/4" and pull the other one out 1/4".
    if you don't have the sensors you don't have anything to worry about.
    absolutely nothing. thats a dealer for ya.
    and you have to remove the license plate lights because you have to remove the black step pad on the top of the bumper because there are 6 bolts you have to access on top and 4 underneath. its not that hard in all actuality.
  15. Mar 28, 2018 at 7:17 PM
    #35
    ejewels
    CT
    Thanks guys. What’s the hardest part and how long did it take? Easy to put everything back together without confusing things?
    And did you question the dealer after that?
  16. Mar 28, 2018 at 7:20 PM
    #36
    trazerr
    Oregon
    Popping out the license plate lights was the hardest part for me. It was tough to see up behind the bumper. Then just putting the right pressure to get them to pop out. After that smooth sailing. Under 30mins start to finish if all goes smoothly.
    rsimi72 likes this.
  17. Mar 28, 2018 at 7:22 PM
    #37
    ejewels
    CT
    So I take it watching that video, you do everything he does up until removing the actual bumper... and instead just loosen all those bolts and realign?
  18. Mar 28, 2018 at 7:24 PM
    #38
    trazerr
    Oregon
    Correct, I didn't completely remove the bumper. I only loosened up all the bolts that held it to the frame. I also don't have back up sensors so I didn't have to worry about those.
    rsimi72 likes this.
  19. Mar 28, 2018 at 7:30 PM
    #39
    JimmySport
    lol, no after they told me that shit I was like, I will just do it myself. that way it will get done. I figured they would send it to their body shop and then they would say it is supposed to be that in case someone hits you, that way we won't have to fix it, it will just correct itself. lol
    ejewels[QUOTED] likes this.
  20. Mar 28, 2018 at 9:07 PM
    #40
    rsimi72
    PNW
    Same for me. Just need to get the step cover off. No need to remove the end caps to align, either. Hardest part for me was popping the lights. Easier the second time but they aren’t the most accessible pieces if you have the hitch.
