OEM Rear Fender Loose
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rollintoy, Feb 13, 2011.
  1. Feb 13, 2011 at 2:54 PM
    rollintoy
    rollintoy [OP] Well-Known Member
    2006 Dbl Cab
    My driver side rear fender is loose at the top (see pic). Looks like the panel may have been hit at one point...how is it suppose to attach?
  2. Feb 13, 2011 at 2:57 PM
    06BLUEDBLSPORT
    06BLUEDBLSPORT Well-Known Member
    Colin
    Lubbock Texas
    12 Tundra DC SR5 4x4 5.7L
    True Dual Flowmaster 40 Series exhaust, Volant CAI, HIDs, Raptor series Side Steps, Weathertech Floorliners, OME 613 Shocks and Coils with Diff Drop, Rear Bilstein 5100 Shocks, ToyTec AAL, Fearless Fabrication Front Bumper
    you probably broke a clip that holds the fender
    the fenders snap on to the truck
  3. Feb 13, 2011 at 6:31 PM
    rollintoy
    Worth fixing, you think?
  4. Feb 13, 2011 at 6:36 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    It's up to you...those clips break very easily.
  5. Feb 13, 2011 at 7:02 PM
    06BLUEDBLSPORT
    Colin
    Lubbock Texas
    if it isnt flush with the truck and theres a gap then i would probably fix it so it will look good
  6. Feb 13, 2011 at 7:26 PM
    Dadic 78
    Dadic 78 Well-Known Member
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    FYI, that's not a "rear fender", it's a "flare". The flares are held on by small plastic clips that break VERY easily when someone tries to remove them.
    They are cheap from the dealer, I think $0.35/each. But, if you decide to replace the missing clips up top on your flare, you'll have to remove your flare, which means breaking all the clips. So, your choice...
  7. Feb 14, 2011 at 4:34 PM
    rollintoy
    Dadic. my bad you're absolutely right...I called it the wrong thing...good catch.
    I will probably let it be for now. The only reason I even noticed is b/c you can see a bit more vibration on that side when driving. There is not a noticeable gap.
