OEM Rear Leafs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Stags863, Mar 2, 2016.
  1. Mar 4, 2016 at 7:51 AM
    Stags863
    Stags863 [OP] Bye Felica!
    Florida
    2014 DCSB TRD Off Road 4x4
    - Bilstein 5100's set at 1.75 - 265/70/r17 Goodyear Wrangler Authorities - 6000k headlight and fog light bulbs - NiLight off road LED rear lights - Light bar mounted behind front bumper - White LEDs in dome, map, and sun visor - Tint (5% around / 35% front) - Universal 13 inch metal antenna - Beer bottle opener in bed - Organizer storage box in center console and glove compartment - Mounted MagLite to top of center console storage box - MGM grille - MGM rear bumper - CamLocker toolbox - Rubber floor mats - 2 USB and Cig lighter chargers in rear of center console - Headrest mounted iPad holders for rear seats
    So after more research and putting the leafs on I decided to keep the yellow on the drivers side and white on the passenger side. This way the colors matched the colors of the coils in the front. That seemed to do it. Rear end of the truck is level. So.....Yellow "Made In Mexico" goes on the drivers side. White "Made In Mexico" goes on the passengers side.
  2. Mar 5, 2016 at 11:07 AM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    Seems to go against the posting listed above...did you have the springs off the truck where you could compare the arch of each against each other as mentioned previously?
  3. Mar 5, 2016 at 2:09 PM
    MarX
    MarX Hotdogs, spam and skittles.
    Mark
    NE Kansas
    2013 DCLB Tacoma TRD sorta Sport 4X4, 2009 Tundra SR5 workhorse
    RETRAX bed cover, Tailgate lock, TRD exhaust. 887's, LR UCA'S, Bilstein 5100's and Deavers AAL.
    Interesting and informative thread!
    Stags863[OP] likes this.
  4. Mar 5, 2016 at 2:56 PM
    Stags863
    Florida
    I did but could not tell a difference between the two. Then again if you compare the stock coils in the front to each other as well you can't tell a difference between the two. The only visual difference is the color markings on the coils. I did however reach out to a friend of mine who has a 2015 that's stock. He climbed under his truck with a small mirror and said his coils were yellow on the drivers side and white on the passenger.
  5. Mar 7, 2016 at 8:40 PM
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Was thinking about this later, realized that the threaded hole in the spring clamp that the brake line bracket bolt mounts to is threaded only on one side of the leaf pack, but not the other, on the oem springs. That's one way to know which side is which.
    surfertaco likes this.
  6. Mar 8, 2016 at 3:52 AM
    Stags863
    Florida
    Good call! I'll have to check mine a little later to see if just that one is threaded. I'm curious now.
  7. Feb 20, 2023 at 4:15 PM
    surfertaco
    surfertaco Active Member
    Andy
    Accesscab Off-road 6spd
    This saved my ass swapping old springs that I bought used !! Thanks hahaha
