OEM Rear View Camera Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fupac133, Nov 6, 2013.
  1. Nov 6, 2013 at 9:48 PM
    fupac133
    fupac133 [OP] Active Member
    Jeff
    Bay Area, SF
    12 PreRunner
    does anyone here know the exact measurement just the rear view camera itself? I would like to replace it with a better quality aftermarket camera. I am trying to find a camera that will fit in the stock location.
  2. Nov 7, 2013 at 5:22 AM
    speedjunkie13
    speedjunkie13 Well-Known Member
    a work in progress
    I'm assuming you already have an OEM camera if you are asking this, so at the risk of sounding like an a**hole, why don't you take yours out and measure it. that's pretty much the only way anybody else would be able to tell you.
    With that out of the way, the oem camera has the built in bracket thing that holds it to the handle, so you would have to fab up a way to hold the aftermarket camera in place. people have done it before though, search around and im sure you can find some examples. I don't really know why you would want to get rid of the oem camera anyhow, seems like a quality picture to me. I had a crappy eclipse camera that somebody else put on before me. I switched it out for the OEM handle and camera and its much better.
    One last thing, the factory camera runs on a 6v feed. most aftermarket cameras will probably be 12v. just keep that in mind.
  3. Nov 7, 2013 at 5:53 AM
    disassemble
    disassemble Well-Known Member
    NJ
    2012 double
    Stop being a princess. You know that oem camera is perfectly fine. Why not install some reverse lights to help u see better at night when u back up.
    Ur welcome
