OEM roof rack bolts?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTuesday1, Aug 10, 2020.
  1. Aug 10, 2020 at 7:09 PM
    TacoTuesday1
    TacoTuesday1 [OP] Well-Known Member
    SD CA
    Searched and found nothing.
    Some chart on 3rd gen forum claims the OEM roof rack bolts are oddball sizes, like 19.7mm or something.
    Question is, for those of you who bought aftermarket, did you use those bolts?
    Or did you find stainless steel replacements at a hardware store?
    If the size really does include 19.7mm, I imagine buying a new bolt would then require it to be cut down to size and maybe ground flat at the end, before chasing the thread with a chaser or tap/die to make sure it's functional before installing.
    I ask because supposedly whatever hardware kit comes with $100 "OEM" style racks (Amazon, eBay, etc.) is weak torx bits that strip easily and rust fast.
    Seems like it could be a good idea to find/match with some higher quality stainless hardware, before installing, so it lasts long (10 years) without rust
    jTtfZuE8bQZ_XS0AtOMSODyhCUnciiNtFPBY7iWa_d33752a062edbf91879f87d4c8d9158b3db50455.jpg
    Philrab likes this.
  2. Aug 11, 2020 at 5:15 AM
    RexsTaco
    RexsTaco Well-Known Member
    Vincent
    San Antonio
    Maxtrac spindles Bilstein 5100 adjustable OME 885 coil JBA UCA's Custom leaf pack and Maxtrac extended shocks in the rear. 35x12.5 Atturo Trail blade M/T Moto Metal 18x12 -44 offset wheels.
    Yes i bought an OEM a while back and the do strip very easily, you could probably go to Lows and get better ones. But then again you aren't suppose to put a lot of torque on those bolt in the first place.
  3. Aug 11, 2020 at 5:20 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    Just buy some bolts that are the closest size down, like 18mm length or something, even 20 (the extra 0.3 mm is negligible). Your overthinking it
    RexsTaco likes this.
  4. Aug 26, 2020 at 5:28 PM
    TheDamnEconomy
    TheDamnEconomy New Member
    2011 Tacoma TRD Off Road
    ARB Deluxe Bullbar, 2" front lift, AAL rear, 9k lbs Superwinch
    I ended up buying ones that were "close enough" e.g. 20mm length and 16mm length instead of the specified OEM lengths. The biggest issue for me has been finding the Pivot Hinge Screw bolt assemblies for the swing arm components... I'm working on trying to track that stuff down now.
    Here's a parts list from another forum post:
    https://www.tacomaworld.com/threads/oem-toyota-roof-rack-bolts-question.589520/
    tacomaroamin likes this.
  5. Aug 26, 2020 at 8:40 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    19.7mm is 0.7755906”
    3/4” is .75”
    The difference is around 1/38th of an inch.
  6. Aug 26, 2020 at 9:01 PM
    Sidney Vicious
    Sidney Vicious Well-Known Member
    NOLAUSA
    2013 Black DCSB Prerunner
    Whatever size you use - don’t forget to use Teflon tape and a healthy dollop of silicone on each bolt when you put it in else it will leak
    beeip and TheDamnEconomy like this.
