OEM roof rack installation
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jesse22876, Mar 3, 2012.
  1. Mar 3, 2012 at 10:51 AM
    Jesse22876
    Jesse22876 [OP] New Member
    Jesse
    New York
    2008 Tacoma doublecab Trd sport
    Smitty light bar. Rims and nitto terra grappler all terrain tires. Toyota factory roof rack added. Body armor foot steps. Toyota Trd exhaust. K& N intake.
    I just purchased the OEM roof rack for the secound gen Tacoma. I was wondering about the installation. I hear it is bolt on. Is it a very invovled process or easy. I generlly install all my mods on my truck myself. Any info would be much appreciated
  2. Mar 3, 2012 at 11:07 AM
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    its easy, just follow the instruction manual
  3. Mar 4, 2012 at 6:06 AM
    fjm0008
    fjm0008 Well-Known Member
    Jack
    Annapolis
    06 4x4 LB White
    Sirius Starmate and ipod integration w/Pay15 Toy USA Spec, Hardwired Radar Detector and GPS, DRL Mod,Tailgate Anti Theft mod, Hi Lift Jack, CB Radio, Back up sensors, Front 30% tint, Leer 100R Cap, Weathertech, Under hood light and 12V outlet, D Rings, N-FAB Step Bars, Bed Mat, Yakima Bike Rack, OEM Roof Rack
    It is an easy installation, I did mine in about 20-25 minutes.
  4. Mar 4, 2012 at 9:02 AM
    AstroluxAtom
    AstroluxAtom Well-Known Member
    Sunnyvale, California
    '05 v6 4.0L DCSB Offroad Prerunner Debadged
    3" Pro-Comp lift kit, Pro-Comp Tires, Magnaflow exhaust dumped at rear axle.
    Where did you buy your roof rack? I want one but I wonder if I should go to the dealer and get it or just keep searching.
  5. Mar 4, 2012 at 9:06 AM
    CopyTaco
    CopyTaco skeeert
    Kins
    Florence, OR
    2010 V6 4x4 DCLB
    OME, Demello, 4xInnovations, Relentless, Murdered Click Sig Pic for Build Log
    Quick and easy as previously mentioned. Just follow the directions and done. Easily 30mins ~ 10 mins per side with 10mins deciphering the directions and sorting your parts.
  6. Mar 4, 2012 at 10:03 AM
    Jesse22876
    Jesse
    New York
    Thanks for the info on install. Just didn't want to get into creating any problems like leaks or whatever. I purchase mine from the dealership as per AsrtroluxAtom. You really don't save money getting it else where and your prob better off getting it at the dealer.
  7. Mar 4, 2012 at 10:14 AM
    PVT Pablo
    PVT Pablo Ultra Junior Member
    Paul
    Chesapeake, VA
    2016 4Runner TRD Pro
    Like others have said its very easy. Do a google search on the rack and check some online stores. I got mine (can't remember where from) for $212 shipped.
  8. Mar 25, 2012 at 10:39 PM
    Palmetto Pete
    Palmetto Pete Well-Known Member
    Pete
    In the Mountains
    2012 SSM TRD Sport DCSB 4x4
    3M Paint Pro Film, OEM Bed Mat, Antenna X, WeatherTech Floor Mats, Foglight Anytime Mod, 8000k HIDs, BFG AT/KOs (265/70/17), Debadged, Ultra-Gauge, Leer 100XR
    I ordered mine last week and it should be here this week. Really looking forward to getting it installed. Does the hardware kit include the required torx bits or do I need to go out and buy them? Thanks for the help in advance!
  9. Mar 26, 2012 at 6:02 AM
    blogs
    blogs Member
    It is an easy installation.[​IMG]
  10. Mar 26, 2012 at 6:38 AM
    jdtemple
    jdtemple Well-Known Member
    Bay Area CA
    08 DBLCAB LB TRD Sport
    Lift & Tires, in cab power outlets, Locking Bed Boxes, K&N
    Make sure your torque wrench is for inch pounds, even tho the directions are labeled ftlb-in. You will easily snap the head of the bolts and turn a 30 minute job into a 3 hour job extracting a bolt :)
  11. Mar 26, 2012 at 7:13 AM
    matts11
    matts11 Well-Known Member
    TN
    You really don't need a torque wrench to do this. If you use a 1/4" ratchet with the hex bit attachment just tighten the bolts until they are snug. Using the small 1/4" ratchet should prevent you from overtightening them--which is what you are trying to avoid. Also, it is pretty typical for the front of the racks on at least one side to not sit completely flush. When you use the awl to pull the front holes into position move it around until you get the most "flush" fit and then snug the bolts down (this should make sense once you read the directions). I did notice on the most recent one I installed that Toyota is now putting some sort of spacer between the rack and the weatherstrip at the front to help it sit more flush.
  12. Mar 26, 2012 at 6:17 PM
    Palmetto Pete
    Pete
    In the Mountains
    Do you know what size hex bits I need? Thanks for everyone's help!
  13. Mar 26, 2012 at 7:22 PM
    matts11
    TN
  14. Mar 26, 2012 at 7:36 PM
    Palmetto Pete
    Pete
    In the Mountains
  15. Mar 26, 2012 at 7:50 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    And the best thing about the HF bits is you can't overtorque the fastener.
    The tool will strip out long before any grade-3 bolt :p
  16. Mar 27, 2012 at 11:28 AM
    Jesse22876
    Jesse
    New York
    When I ordered mine it came with all the hardware to install it
  17. Mar 28, 2012 at 4:23 PM
    Palmetto Pete
    Pete
    In the Mountains
    Installed mine last night . . . Pictures to follow later. I have a small gap on both my passenger and driver side. After reading all of the other posts about the OEM roof rack I figure this is normal. Any thoughts?
  18. Mar 28, 2012 at 5:08 PM
    jdtemple
    Bay Area CA
    Not everyone has torque sensitive hands, and it would be very easy to over tighten & break a bolt or chew threw the plastic, or under tighten and have your rack get lifted off your cab with all your gear. You also want to make sure you tighten to specs to allow the mastic washers to seal the bolt holes water tight to prevent leaks.
    Read the instructions provided by toyota and follow the torque specs.
    <sarcasm>
    OP, I quoted the above post for future reference in case your rack flies off, or your break a bolt, or your cab leaks.
    Matts11 sounds like a certified mechanic, and you should ask him if he is willing to back any advice he gives about installing the roof rack with his very own wallet. ;)
    </sarcasm>
  19. Mar 28, 2012 at 5:21 PM
    jdtemple
    Bay Area CA
    The brackets that you install forward of the cab can be bent a little bit to decrease or eliminate that gap. Its to late now unless you order some new mastic washers and remove the rack, bend the bracket where the yellow locking click goes in a little bit forward, then install the rest of the racks.
    I found it while searching a thread about the same issue. It bugged me enough to fix one side.
  20. Mar 28, 2012 at 7:35 PM
    matts11
    TN
    I would leave it alone. It will not cause leaks or any wind noise. The fix above rarely works in my experience. The reason why is because the rack "bottoms out" on the bracket when trying to pound the yellow clip into the hole. If you bend it down it will just bottom out and the clip will go in less. There is almost no way to get any leverage on the bracket to hold it place while trying to pound the clip in. You can stick a thin plastic trim tool under the rack and try to do it but I never had much luck with it. The bracket you want to bend is the back part of that bracket. I would not stress about any leaking if you remove the rack. Just get rid of the gunk left by the mastic washers and use butyl tape around the holes. The butyl will compress when you tighten the rack down and do the same job as the mastic washers. I am not sure you can even get the washers outside of a new rack. You can order a roll of butyl tape off of Amazon. Anyhow, below are pictures of the rack on my truck, you can see there is a slight gap on both sides in the front. If you want to mess with yours, just loosen the back bolts, remove the front two, and try moving the rack with an awl to see if you can get the front more snug.
