OEM Roof Rack Leak
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SOLID, Jul 1, 2018.
  1. Jul 1, 2018 at 8:55 AM
    SOLID
    SOLID [OP] Well-Known Member
    Jamie
    Louisiana
    2017 Magnetic Gray Tacoma TRD Off Road
    265/70R16 Duratracs SPC 25470 Upper Control Arms Old Man Emu 90021-P Nitrocharger Sport Front Shocks Old Man Emu 887 coils Old Man Emu 60091-P Nitrocharger Sport Rear Shocks Old Man Emu EL119-P Leaf Springs Old man Emu Carrier Bearing Drop Cali Raised Kick Out Rock Sliders Goose Gear Rear Seat Delete WeBoost Signal Booster Switch Pro SP9100 8-Switch Panel Power System Vertical Switch Pro PowerTray with install kit Cali Raised Off Road Switch Pro Mounting Panel upTOP Overland | 38" Dual Function Light Bar Baja Design rock lights - w/ scenePOD 2.0 - 4 - Roof Rack - Bed lighting - 2 - ground - frame - 6 UpTop Bravo Roof Rack UpTop Truss MID Height Bed Rack Mountain Hatch Tailgate Insert Cali Raised LED - Bed Channel Supports 23Zero RTT - Breezeway 62 with LST 23Zero Canopy Condition 1 Case - Roof mount WaterPORT 3.8-gallon self-pressurized water tank Joolca HOTTAP camp shower system Desert Does It Seat Jackers - 2 Desert Does it Front Multi Mount Panel Element fire extinguisher Hi Lift Jack Hondo Garage Un-Holey Phone Mounts - 2
    A couple of months after installing my OEM roof rack and Yakima Megawarroir (with extension...don't forget the extension!) I now have a leak. It dumps a 1/4 cup of water into my shoe and/or soaks the seatbelt.
    I'm thinking I've got to take it off, check it out, silicone the bolt threads, torque it back down.
    Anything else I should look for/do/consider?
    Thanks!
  2. Jul 1, 2018 at 9:00 AM
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    Silicon around the mounts once it’s screwed back in. It should be concealed by the gasket I think.
    trdmikey8 and SOLID[OP] like this.
  3. Jul 1, 2018 at 9:13 AM
    SOLID
    Jamie
    Louisiana
    Would you recommend tossing the OEM foam gaskets that came in the installation kit?
  4. Jul 1, 2018 at 9:29 AM
    SOLID
    Jamie
    Louisiana
    Are you saying silicone around these brackets?
  5. Jul 1, 2018 at 10:26 AM
    strktly_bodysurf
    strktly_bodysurf Well-Known Member
    Had the same problem. Just take it off and seal all bolt holes.
    quicksandjohnny likes this.
  6. Jul 1, 2018 at 2:14 PM
    Norsemanvike
    Escondido, CA
    Sorta. Like @strktly_bodysurf said, seal the bolt holes with clear or black silicon and if you can see anywhere that water might sneak in, more silicon. Just make sure you smooth out the surface and use something clean up the edges if it gets on the paint.
  7. Jul 1, 2018 at 2:31 PM
    strktly_bodysurf
    x2
    It's crazy that they made these holes pass through to the cab interior
    helix66 likes this.
  8. Jul 2, 2018 at 7:03 AM
    SOLID
    Jamie
    Louisiana
    What's more fun, when I put my torque wrench on the bolt, it snapped-off into the mount. HOUSTON....WE HAVE A PROBLEM! Had my zen moment and didn't freak out. Guess that hardware isn't meant to be used more than once!
    So while I find the correct replacement bolts, I'm assuming y'all are tossing the squished foam washers, right?
  9. Jul 2, 2018 at 8:36 AM
    strktly_bodysurf
    Lol
    Hell yeah those washers are a joke. It's toyotas attempt at protecting their own rear end by supplying us with "waterproofing"
  10. Jul 2, 2018 at 10:04 AM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Replace the crap hardware with stainless.
    Heads will strip out on oem stuff. Don't ask how I know.
    There is that one long bolt you won't find in stainless on the arm.
    RepoMarket and SOLID[QUOTED][OP] like this.
  11. Jul 2, 2018 at 10:05 AM
    2016Tacoman
    J
    Better that than to find out one day its rusted through by a hole made over the years because water couldn't get out in the threaded area. It's an indication it wasn't installed right.
    minium and SOLID[OP] like this.
  12. Jul 2, 2018 at 10:28 AM
    SOLID
    Jamie
    Louisiana
    Misery loves company, right? Yesterday one of the front mount bolts broke off.
    Where can I find the M6x15.77mm, M6x40mm & M6x19.7mm bolts? Didn't have any luck at my local Lowes.
  13. Jul 2, 2018 at 10:31 AM
    2016Tacoman
    J
    Look in the speciality boxes, you know the ones that pull out.
    Thought they had them.
    You might not be able to get the exact length but should find something that will work.
    Also get a couple of these. They can break when removing.
    End Cover Clip - Toyota (90080-46314)
    shakerhood likes this.
  14. Jul 11, 2018 at 11:01 AM
    SOLID
    Jamie
    Louisiana
    Thanks to everyone for their suggestions. Replaced hardware with stainless from Lowes (slightly longer, no problems), a dab of blue loctite and generous rings of silicone around each bolt hole. Has been a few days and heavy rains, so far, so good!
    Norsemanvike likes this.
  15. Nov 11, 2018 at 9:33 PM
    4x4yotaphan
    4x4yotaphan Well-Known Member
    SoCal
    SOLD: 2016 White TRD Sport DCSB 4x4
    Exterior: King suspension w/compression adjusters Icon billet UCAs Icon 3 leaf expansion pack Timbren rear bump stops w/U bolt flip kit Wheeler’s Offroad front superbumps BFG KO2 285/70/R17 on SCS Ray 10 17” wheels w/black wheel lock lug nuts TRD Pro grill TRD Pro taillights TRD Pro skid plate Demello Offroad front bumper Smittybilt XRC 9.5 comp winch w/Factor 55 fairlead and Flatlink E RCI LCA skids Beast Fab rock sliders 4 Extreme LED 4” pods Baja Design Squadron SAE LED amber fog lights Relentless Fab bedrail mount w/KC Flex dual amber chase lights AVS vent visors Interior: TRD Pro shift knob OEM instrument switch panel conversion (from 3 to 5 slots) Taco Garage DMM with Scosche Magicmount Upgraded Kicker sound system Husky X-act floor liners Performance: Airaid cold air intake system Pedal Commander w/Bluetooth
    Are the bolts M6x1x(length)? What lengths did you get and quantities of each? Also bolt head style since the instructions does say wafer head and button head. Sorry so many questions, stripped a bolt and wanted to replace all of them with stainless.
  16. Feb 9, 2019 at 8:47 AM
    Toms 17
    Toms 17 Well-Known Mumbler
    Tom
    Central Ohio
    17 MGM DCSB TRD Sport
    I just bought some rubber washers to replace the foam ones before I do my install.
    shane100700 likes this.
  17. Feb 9, 2019 at 9:38 AM
    JNG
    JNG Shitposter extraordinaire
    2019 Silver TRD OR DCSB 4x4 AT P&T
    Ya'll need to become familiar with McMaster-Carr. Can't tell you how many threads I've read where some poor schmuck is looking for a fastener at Lowe's or some chain hardware store at can't find it.
  18. Feb 9, 2019 at 9:47 AM
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    Buy slightly longer ones and use an angle grinder to get it to the right length.
    The local Ace hardware has a far better selection than the lowes or HD, but for an oddball length dremel or grinder.
    Foe those of us that don't have a roof rack installed, how were those holes into the cab plugged up??
    Wonder if they can become a problem.
  19. Feb 9, 2019 at 9:50 AM
    Dcross
    Dcross Well-Known Member
    Southern Illinois
    2017 Super White TRD Off Road Dbl cab
    I second the McMaster-Carr suggestion. I have used them for years. Great source if you need something out of the ordinary.
    MikeyD.25 likes this.
  20. Feb 9, 2019 at 9:52 AM
    helix66
    DPRC
    2017 DclB TRDor MgM
    Sounds like others are using silicone in the hole & the supplied washer.
    https://www.tacomaworld.com/threads/roof-rack-install-question.549439/
    Arrex likes this.
