OEM Roof Rack Leak
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SOLID, Jul 1, 2018.
  1. Nov 4, 2020 at 7:34 AM
    #41
    gluvva
    gluvva Well-Known Member
    2020 Tacoma TRD sport DCLB MGM
    Yup, this was also a big issue. If your truck is still within warranty they will fix this at the dealer.
  2. Nov 4, 2020 at 7:45 AM
    #42
    acsarm
    acsarm Well-Known Member
    NW WA
    ‘16 SW DCSB OR
    LEER 100R DD SS3 TRD Pro SEMA Wheels Bilstein 6112/5160 Archive Garage Hammer Hangers Icon RXT (3) Rear Sumo Springs 612-40 Decked Drawers
    If it’s the third brake light/rear window leaking, there’s no chance that there would be water traveling across to the front end of the cab. The headliner helps to localize the leak because of its concave shape, so there’s no path for water to actually travel up there. So it seems like it would still be your roof rack leaking unfortunately.
    SOLID[QUOTED][OP] likes this.
  3. Nov 4, 2020 at 7:48 AM
    #43
    SOLID
    SOLID [OP] Well-Known Member
    Jamie
    Louisiana
    2017 Magnetic Gray Tacoma TRD Off Road
    265/70R16 Duratracs SPC 25470 Upper Control Arms Old Man Emu 90021-P Nitrocharger Sport Front Shocks Old Man Emu 887 coils Old Man Emu 60091-P Nitrocharger Sport Rear Shocks Old Man Emu EL119-P Leaf Springs Old man Emu Carrier Bearing Drop Cali Raised Kick Out Rock Sliders Goose Gear Rear Seat Delete WeBoost Signal Booster Switch Pro SP9100 8-Switch Panel Power System Vertical Switch Pro PowerTray with install kit Cali Raised Off Road Switch Pro Mounting Panel upTOP Overland | 38" Dual Function Light Bar Baja Design rock lights - w/ scenePOD 2.0 - 4 - Roof Rack - Bed lighting - 2 - ground - frame - 6 UpTop Bravo Roof Rack UpTop Truss MID Height Bed Rack Mountain Hatch Tailgate Insert Cali Raised LED - Bed Channel Supports 23Zero RTT - Breezeway 62 with LST 23Zero Canopy Condition 1 Case - Roof mount WaterPORT 3.8-gallon self-pressurized water tank Joolca HOTTAP camp shower system Desert Does It Seat Jackers - 2 Desert Does it Front Multi Mount Panel Element fire extinguisher Hi Lift Jack Hondo Garage Un-Holey Phone Mounts - 2
    Acsarm, sorry if my post wasn't clear. The leak is coming down the rear window, on the driver's side.
  4. Nov 4, 2020 at 7:49 AM
    #44
    SOLID
    Jamie
    Louisiana
    Gluvva, here's a video of my light gasket. There is some play in it. Is this what yours looked like before replacement?
    https://youtu.be/DzLGcO_69_I
  5. Nov 4, 2020 at 7:52 AM
    #45
    gluvva
    I would go to the dealer and get this sorted out if you still have warranty. but usually third brake light issue is going to be in that area not the 2nd row windows.
  6. Nov 4, 2020 at 8:02 AM
    #46
    acsarm
    NW WA
    ‘16 SW DCSB OR
    Have you tried spraying the area with a hose to diagnose where the leak is coming from? I would try spraying just the rear windows first to see if they do, if not then I would travel up the roof rack to where the rear bolts are at and check there.
  7. Nov 4, 2020 at 8:03 AM
    #47
    SOLID
    Jamie
    Louisiana
    I hear ya. Unfortunately, I'm over 36K. Also, I installed the roof rack, and have pulled it a couple of times. It's obvious that it's not a factory issue. I certainly don't want to accumulate any bad vehicle karma by trying to push this off on somebody else.
  8. Nov 4, 2020 at 8:04 AM
    #48
    SOLID
    Jamie
    Louisiana
    That's a solid game plan. I'll do that and report my findings. Thank you for your help.
    acsarm[QUOTED] likes this.
  9. Nov 4, 2020 at 7:52 PM
    #49
    17Tacos
    17Tacos 2017 Limited 4WD
    Robert
    Wanting to leave California
    5100's, ICON 1.5 rear add a leaf, train Horn, LED light Bar, hardwire front camera, LED headlights, taillights, and interior.
    I had the same issue with the third brake light leaking and took my 2017 to the Dealer and they didn't question replacing it along with the headliner outside the 36K mile warranty. I think it is a silent recall and if dealer won't do it call Toyota directly. Be you own advocate, this is a bad design issue and tell them you might have mold growing and have seem so many with the same issue on Tacomaworld and other forums. That will get their attention!
    tacorunadam and SOLID[OP] like this.
  10. Nov 7, 2020 at 10:12 AM
    #50
    SOLID
    Jamie
    Louisiana
    UPDATE! Hose tested the brake light assy. Leaks like a sieve. Thank you all for helping me get to the root of this problem!!
    Malvolio likes this.
  11. May 22, 2021 at 7:55 PM
    #51
    Woodzyzewski
    Woodzyzewski Well-Known Member
    Woodrow
    West Virginia
    2018 Inferno TRD Off Road DCSB
    I bought one of these. It’s in the mail. Been reading and watching a lot of videos. Basically it’s going to leak if I don’t replace foam washers with rubber, put thread seal tape around the threads and then RTV silicone around all the screws correct? Also, would it help to RTV silicone the entire big channel that that black rubber strip occupies before installation or would that just be a waste?
  12. May 22, 2021 at 8:21 PM
    #52
    SOLID
    Jamie
    Louisiana
    I just used silicone around all of the screws and have had no issues. Naturally, after getting everything perfect I'm going to dump the OEM rack and replace it with an upTOP Overland rack. o_O Good luck with your mod!
  13. May 22, 2021 at 10:15 PM
    #53
    mysubiewasalemon
    mysubiewasalemon Well-Known Member
    You want to sell the oem rack ? If so how much and pick up location
  14. May 24, 2021 at 4:27 AM
    #54
    bonifacio
    bonifacio Well-Known Member
    Central PA
    2019 Cement Gray Tacoma OR 4x4
    Good choice. I went this route. Go ahead and order the 3/4" punch. Also, try to cut the wire inside the channel liners before punching it. I didn't and it shifted. I also ended up stripping one of the holes. Was kind of hard to line up. But I drilled it out and just used a nut and washer. They have you silicone the top where you punch the wholes in the liner. I took it further and threw some silicone on the inside above the headliner. It's easy to access. Hit me up if you want me to explain how to get to them.
  15. May 24, 2021 at 7:01 AM
    #55
    SOLID
    Jamie
    Louisiana
    It may be a couple of months before my new rack comes in. But yes, once I've got the upTOP rack installed I'll sell the OEM rack.
  16. Dec 28, 2023 at 2:30 PM
    #56
    kylecrish
    kylecrish Well-Known Member
    Cel. Silver 2023 Tacoma TRDOR
    I know this is an old thread at this point, but I just noticed my roof rack is leaking and I'll be following the suggestions here.
    I went to the dealer to see if this would be covered under warranty and they said I'd be on the hook since I installed the roof rack. They explained that "if I tightened the screws too much, I would brake through the bottom of the screw holes". Is that a thing?? Do the holes have a bottom and is the clearance that tight? Or are they just holes and the shitty foam gaskets barely do anything?
  17. Dec 28, 2023 at 3:52 PM
    #57
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    I’d love to see someone cut open a wrecked 2016 in a junkyard so we could see the side profile of the bolt holes and third brake light area. It’s such a botched design that makes Toyota look like it’s engineers never built a vehicle with a roof before. Sorry, man. I feel you.
  18. Dec 28, 2023 at 3:59 PM
    #58
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    Did you get it installed? Don't leave us hangin..
  19. Aug 1, 2024 at 4:24 PM
    #59
    GawainXR
    GawainXR Well-Known Member
    William
    2020 TRD Off-Road
    DashCam
    I just picked up the OEM roof rack and am a bit sus of the foam seals and whether they'd deteriorate pretty quickly.
    Are you folks substituting 1/4" ID x ~3/4" OD neoprene washers of a similar thickness in their place?
    I'm thinking of swapping those foam washers for Neoprene ones and then coating the bolt threads with a healthy amount of marine silicone sealant.
  20. Aug 1, 2024 at 4:50 PM
    #60
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    I’ve done my first roof rack and a friends where they were both second hand. I just did another and I’ve had ZERO leaks. Use 3M automotive double side tape (7/8”). use punches (I’ll get the sizes) and cut circles from the tape with center hole. Use those instead of the foam. Poke the hole for the bolt in the body tape using an awl or Phillips screwdriver. Place the ring around the hole by placing the ring on the bolt… screw in to start and slide the ring until it contacts the body. Remove bolt and install bracket and then rail. You want water to be able to pass around, but not access hole. I have photos from years ago somewhere…
