OEM Roof Rack Leaking:Help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dirty Harry, Mar 21, 2018.
What should I do?
  1. Fix OEM
    5 vote(s)
    26.3%
  2. Prinsu all the way!
    13 vote(s)
    68.4%
  3. Other
    1 vote(s)
    5.3%
  1. Mar 21, 2018 at 8:38 AM
    Dirty Harry
    Dirty Harry [OP] Well-Known Member
    Andrew
    SW Florida
    2021 Tacoma 2.7 SR 4x4
    So late Spring/early Summer last year I purchased the OEM roof rack off Amazon. I followed the directions very closely and used all the supplied hardware. However, I've noticed that any time it rains and my Truck is parked downhill I get the worst leak in the middle pillars. It totally soaks my seatbelts on both sides.
    I'm already not very thrilled with the limited weight capacity of the OEM rack, so I'm considering my options. Knowing that I'm gonna have to pull it off to deal with the leak I'm thinking about upgrading to the Prinsu.
    Does anyone know if the Prinsu comes with weather stripping?
  2. Mar 21, 2018 at 8:58 AM
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    Did you silicone the threads on the bolts that go into the roof?
    Check out @Dissent86 cab racks.
  3. Mar 21, 2018 at 9:35 AM
    OdiN1701
    OdiN1701 Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    The Prinsu does not, but you can use the OEM weather stripping and drill holes in it.
    You're still going to want to silicone the hell out of the bolt areas.
    shakerhood and Gunshot-6A like this.
  4. Mar 21, 2018 at 9:41 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Silicone the bolt holes to fix the underlying issue, then research roof racks.
    If you do go Prinsu, I have the 3/4 inch punch to make the holes that you can have for shipping cost.
    Murdoch33 and 007WillyWoo like this.
  5. Mar 21, 2018 at 9:45 AM
    Chatt69chgr
    Chatt69chgr Well-Known Member
    2017 Quicksand Tacoma TRD 4X4 OFFROAD
    None
    There is info on here about the Prinsu roof rack that talks about installing one on a 3rd gen. Siliconing the installation bolts should take care of any leaking issues. No place else for the water to get in. As far as the weatherstripping is concerned, the same thread talks about how to deal with it. You need a 3/4" punch to make a hole in the weather stripping. The thread talks about the type of punch and how to accurately make the hole. Don't recall if it talks about what adhesive to use to reinstall the weather stripping but 3M has a clear weatherstrip adhesive that would do the trick. What the thread cautions is not to use a hole saw to try and make the 3/4" hole. Need to use the punch. They don't cost but $15 or $20 off ebay. You can search for this thread or maybe someone else has a link to it. I'm about to order the Prinsu rack myself. Just have not pulled the trigger yet.
  6. Mar 21, 2018 at 9:48 AM
    OdiN1701
    Colorado
    Funny, as Prinsu says to use a spade drill bit I think.
  7. Mar 21, 2018 at 9:51 AM
    007WillyWoo
    007WillyWoo Well-Known Member
    TJ
    2012 DCSB TRD OffRoad
    Used a spade bit, had to buy replacement weather strips. Don't use a spade bit.
    here4cake and TACOVRD like this.
  8. Mar 21, 2018 at 10:00 AM
    OdiN1701
    Colorado
    Use a drill press?
  9. Mar 21, 2018 at 10:01 AM
    007WillyWoo
    TJ
    Leather hole punch
  10. Mar 21, 2018 at 10:02 AM
    OdiN1701
    Colorado
    No I'm asking if you used a drill press with the spade bit. I don't think I'd try it by hand.
  11. Mar 21, 2018 at 10:04 AM
    Hextall
    Hextall Well-Known Member
    NH
    17 Inferno OR DCSB
    No, the prinsu does not come with weather stripping. however a few people installed the prinsu without the OEM weather stripping. You put a good size dollop of silicone over the holes and put the bolts through. that's what keeps water out, not the weatherstipping.
    I'm not sure that weatherstripping does anything except fill that space and is for looks. I don't believe it completely seals that channel. Without a OEM roof rack, the holes are already taped over and sealed.
  12. Mar 21, 2018 at 10:06 AM
    Dirty Harry
    Andrew
    SW Florida
    Thanks for the info. Now I'm really torn. I think I want to ditch this OEM.
  13. Mar 21, 2018 at 10:07 AM
    Hextall
    NH
    17 Inferno OR DCSB
    I very much like my prinsu, and know that I'd like it over the OEM.
  14. Mar 21, 2018 at 10:09 AM
    Hextall
    NH
    17 Inferno OR DCSB
    FYI, there's someone on the 3rd gen marketplace that has started a feeler thread about doing a Prinsu group buy. CBI, who owns prinsu now, never does group buys... but you might want to tag along with that effort to see if it actually happens.
    I'd give it a 3.7% chance of happening.
  15. Mar 21, 2018 at 10:13 AM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    I’ve been debating a roof rack just for this reason - another place water can potentially get in but I know many have installed without issues.
    Probably a stupid question, but for the mounting locations on the roof for the rack, is there an engineering reason why they couldn’t have just had some threaded blind ended holes for the mounts as opposed to going all the way through the cab? Seems like a poor decision in the design of the mounts?? :notsure:
  16. Mar 21, 2018 at 10:13 AM
    Gunshot-6A
    Conner
    Everett, WA
    I give it a snowball's chance, but who knows?
    Especially since they and everyone else knows they are sitting on a product that basically all are willing to pay sticker for.
    Mass production assembly line ease is my guess. Why bother welding in threaded pockets, when you can just drill a threaded hole?
  17. Mar 21, 2018 at 10:14 AM
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    The combo cab and bed rack system he has designed is at the top of my list.
  18. Mar 21, 2018 at 10:27 AM
    007WillyWoo
    TJ
    Used a hand drill. Not sure if a drill press would change the outcome, the friction coupldd with the pliable nature of the weather strip after removing the steel band cause the strip to wrap around the bit. I tried both a hole saw and spade bit, hole saw had better results for the wrap issue but left really rough edges.
    The punch left clean holes and no wrap issues.
    Picked up a set off Amazon for <$20 and it took about two hours for the full install.
    here4cake likes this.
  19. Mar 22, 2018 at 8:52 AM
    Rujack
    It’s awesome. Was my very first mod. I’ll be picking up the side doors for it in the next week or two.
    Dissent Off Road is his brand if anyone’s interested
  20. Mar 22, 2018 at 9:43 AM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I used a spade bit when doing my prinsu and had no issues. That being said changing racks isn't going to help OP with his underlining issues.
