OEM Roof Rack Leaking:Help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dirty Harry, Mar 21, 2018.
What should I do?
  1. Fix OEM
    5 vote(s)
    26.3%
  2. Prinsu all the way!
    13 vote(s)
    68.4%
  3. Other
    1 vote(s)
    5.3%
  1. Mar 22, 2018 at 10:59 AM
    knhallak
    knhallak Well-Known Member
    Khalil
    Laguna Hills
    '12 Black Tacoma
    Kenwood Deck Side Rails Tonneau G2 Bakflip Interior LED WeatherTech Floor Liners and Bed liner Wet Okoles Seat Cover K&N Intake Filter CB Radio + Firestik Antenna Baby Monitor (aka backup camera wired to display image when pressing a CH4x4 switch Hidden LED light bar in Front bumper Ditch lights Bed lights ADDED OEM Deck outlet
    I had both and I am sure glad I bought the Prinsu!
  2. Mar 22, 2018 at 11:19 AM
    G562
    G562 Active Member
    California
    2017 Black Tacoma Sport
    Are you guys suggesting to either use a punch or a spade to drill the hole on the weatherstrip?
  3. Mar 22, 2018 at 11:22 AM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I cut the metal spine out then used a good spade bit at slow speed with no issues.
  4. Mar 22, 2018 at 11:26 AM
    G562
    G562 Active Member
    California
    Im assuming using a regular drill? I dont know if I trust myself enough to do it without damaging it.
  5. Mar 22, 2018 at 11:37 AM
    Lt. Dangle
    Ohio
    Then try a punch lol. It's not really as scary as it sounds, you just need to use the proper speed on the drill. I'd bet good money most people with issues try to zip right through it. A good sharp bit is also important.
  6. Mar 22, 2018 at 11:40 AM
    G562
    G562 Active Member
    California
    Hahaha it sure does. I might do it with a drill, its 3/4 spade?
  7. Mar 22, 2018 at 11:43 AM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    My oem rack sucked, so I got a front runner. To seal i filled the bolt holes with flex shot and it's never leaked
  8. Mar 22, 2018 at 12:16 PM
    Lt. Dangle
    Ohio
    That part I forget. I just watched the size f the spade to the size of the stand offs on the rack.
    Seriously though if you are concerned, go the punch route. I'm sure it's less stressful.
  9. Mar 22, 2018 at 12:19 PM
    G562
    G562 Active Member
    California
    Ill look into the size, thanks. Ill just hold you accountable for my mistakes :D. Ill take a look at that as well. Thanks for the help.
    Lt. Dangle[QUOTED] likes this.
