OEM Roof Rack MOD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by garrettmiklautz, Jul 17, 2017.
  1. Jul 17, 2017 at 7:40 PM
    garrettmiklautz
    garrettmiklautz [OP] Well-Known Member
    Garrett Miklautz
    2013 Tacoma Double Cab-Super White
    Hey guys,
    First post here on TacomaWorld, but long time viewer.
    My current roof rack setup includes the OEM rack on the cab, and Thule Steel Bars on my Leer Cap. Im content with the current setup, and not looking to splurge on a front runner rack of sorts at the moment.
    The issue i am having is the Thule bars sit roughly 1 3/4" higher than the OEM bars. I've been brain storming ways of perhaps adding onto the OEM bars to make up the height so they are flush horizontally.
    This mainly becomes an issue when i want to throw long stuff up there like a canoe, 2x4's ect.
    My current idea's include: Surf rack pads or mounting a strip of properly dimensioned lumber.
    I don't mind the surf pad idea, but there hard to find in long lengths. The OEM bars measure 34". The lumber idea would certainly work.. i'd probably only use the wood when needed, but would like to keep something on there that looks a little nicer than lengths of wood.
    If anyone has any ideas on this it would be greatly appreciated.
    Thanks!!
  2. Jul 18, 2017 at 7:34 AM
    TxFireman
    TxFireman Factory Pilot
    San Antonio, Texas
    2013 DC-SB TRD-OR, tow package, entune/nav
    I'd probably just try to find a thick pad, something along the lines of a pool noodle, and only use them when you're hauling something long. The rest of the time I'd just leave them off. I wouldn't be too concerned with the front being lower, myself. I would think it might even help the air flow over something like a canoe if the nose was an inch and a half lower up front. That way when you're on the road the air is likely to push down on the canoe instead of trying to pull it up away from the rack. Just my 2 cents of course.
  3. Jul 18, 2017 at 7:37 AM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    The pool noodle would work, but foam pipe insulation would also work and the black color is closer to the color of the rack...check Home Depot, Lowe's, or any good hardware store...and the pipe insulation is usually split lengthwise to make it easier to slip on and off the crossbars, and can be secured with hose clamps or something similar that is easily removable.
  4. Jul 18, 2017 at 7:48 AM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Front Runner Group Buy is active until Friday July 21st. 15% off plus free shipping.
    Just saying...
    https://www.tacomaworld.com/threads/front-runner-racks-2-0-group-buy.497817/
  5. Jul 18, 2017 at 8:58 AM
    WillyJam
    WillyJam Well-Known Member
