OEM roof rack problem?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by spencer82, Dec 6, 2016.
  1. Dec 6, 2016 at 5:56 AM
    spencer82
    spencer82 [OP] Member
    TN
    2017 SR5 Double Cab
    I installed a factory roof rack on my 2017 Tacoma last night. Install was easy, but I have about a 3/16" gap between the rack and window channel on each side. This is how the holes lined up. Will this still drain properly or do I need to try to fill this gap? Anyone else run into this?
    ChadsPride likes this.
  2. Dec 6, 2016 at 5:58 AM
    tacopasu
    tacopasu Well-Known Member
    2016 Blue TRD Sport LB 4x4
    Great. Looks good.
  3. Dec 6, 2016 at 5:32 PM
    Thirty5
    Thirty5 Well-Known Member
    SGV 626
    17' 4x4 OR Prem, tech, JBL
    The front passenger side of my rack has a gap too. Does water leak into the cabin?
  4. Dec 6, 2016 at 5:51 PM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Normal.
  5. Dec 6, 2016 at 7:06 PM
    spencer82
    TN
    2017 SR5 Double Cab
    There was a big rain here all day and cabin is dry. It's well sealed, it just still irks you a little bit when you end up with a gap.
  6. Dec 6, 2016 at 7:10 PM
    fajitas21
    fajitas21 XMF - Extreme Mexican Food fo Life!
    Lee
    Collierville, TN
    4Runnerzzz
    Originally not Expo AF! Kinda Expo AF now...lame.
    Yours looks better than mine and it just DOWNPOURED for 3 straight days in SE Texas and not a drop in the cab. I think your'e ok, but watch it for the first few good rains. If you have problems, you'll need to disassemble and use locktite in the threads to seal, or maybe some silicone. Your call. Honestly though, it's probably fine.
  7. Dec 9, 2016 at 2:02 PM
    Thirty5
    SGV 626
    I'm getting leaks on both sides of the seatbelts when I run my truck through the car wash. I installed the rack myself with no instructions, does it come with silicone to seal the bolts? Any help is appreciated.
  8. Dec 9, 2016 at 2:55 PM
    spencer82
    TN
    2017 SR5 Double Cab
    Mine had adhesive washers to go with the bolts.
  9. Dec 9, 2016 at 2:58 PM
    Hot Tacoma Blown
    Hot Tacoma Blown Well-Known Member
    NewYork
    05 4×4 tacoma
    Super charged,urd u - conn computer 7th injector, headers, pipe bomb y pipe,high flow exhaust.etc....
    Need to watch and see.looks good. Hopefully no problems..
  10. Dec 9, 2016 at 3:19 PM
    textoy
    textoy Well-Known Member
    Fred
    Texas
    2011 4x4 TRD DC
    I used a silicone sealant that comes in a small white tube that I got at lowes that I used when I put a Baja rack on my FJ. Don't overdo it though. Can't remember the name of it, though...
  11. Dec 9, 2016 at 8:08 PM
    fajitas21
    Lee
    Collierville, TN
    4Runnerzzz
    Yea, clean the area, put down some silicone where the bolts go in. Run of the mill silicone will do fine, I tend to use GE brand. I have installed countless lightbars for police vehicles with just a grommet and silicone, and no leakage. It's great stuff.
  12. Dec 9, 2016 at 8:18 PM
    Thirty5
    SGV 626
    Thanks guys
  13. Dec 9, 2016 at 8:19 PM
    redbull9944
    redbull9944 Well-Known Member
    Southwestern PA
    ‘24 LC250 First Edition, ‘25 TRDOR 6MT, 2016 DCSBTRDOR Inferno 6MT, 2004 Double Cab 4WD Project
    Prinsu Rack, 275/70R17 Cooper ST MAXXs, TRD PRO 4Runner Wheels, 5100s
    Looks fine to me.
    I actually ran into a problem installing my Prinsu rack. The sheetmetal was misaligned on the roof when welded and some of the factory holes weren't fully exposed. They were an oval shape instead of a hole shape. Took it to the dealer and they drilled out new holes in their body shop under warranty. No leaks. If yours was professionally installed, or you followed the directions installing, you shouldn't have a problem
  14. Dec 20, 2016 at 7:40 PM
    fiveofun
    fiveofun Active Member
    Kevin
    2017 TRD ORDC 4X4 Quicksand
    Stock
    What is the distance between the two cross bars when they are going side to side?
  15. Dec 20, 2016 at 8:21 PM
    fajitas21
    Lee
    Collierville, TN
    4Runnerzzz
    Approx 43"
    fiveofun likes this.
  16. Dec 21, 2016 at 8:05 PM
    fiveofun
    Kevin
    Stock
    Does anyone have an exact measurement they can share? The Yakima Megawarrior rack I want to put on top of my Tacoma needs the crossbars to be a max of 38" apart. The bars are not adjustable, correct?
  17. Dec 22, 2016 at 6:21 AM
    fajitas21
    Lee
    Collierville, TN
    4Runnerzzz
    I did lots and lots of research and then bought one simliar.
    It's 43", and that rack won't fit unless you buy the 18" extension, which will then cause it to hang a bit.
    The factory crossbars look good, but are very limited in which baskets will fit. The problem is the designs of most baskets assume the crossbars can slide toward and away from the front of the cab to adjust for the connecting pieces that (on the baskets), can only move side to side.
    What you need is a basket where you can reach at least 46" and the mounting point can move forwards and backwards, to accommodate the OEM roof rack. The only ones I found were in the $400 + range, and at that I'd probably just sell this thing and buy a Prinsu rack.
  18. Dec 22, 2016 at 6:23 AM
    fajitas21
    Lee
    Collierville, TN
    4Runnerzzz
    Oh, another solution for you. Leave the OEM crossbars at their sides, and buy some additional crossbars that connect to them, which makes your setup adjustable.
    Extra cost, but I think Thule had a system that worked and it would then allow you to fit just about anything you want up there.
  19. Jan 23, 2017 at 2:23 PM
    kwest10
    kwest10 Member
    Los Angeles
    2016 TRD Sport 4x2
    Can anyone confirm that the loadwarrior will fit the OEM roof rack? I kept my loadwarrior from my Xterra but those crossbars were adjustable. Don't want to have to buy bars to put on bars to put the basket on. Thanks
  20. Jan 23, 2017 at 2:27 PM
    dusman
    dusman Well-Known Member
    Dustin
    Windsor, Maine
    2017 TRD ORDC MGM
    looks normal to me, spray with a garden hose for a bit and monitor, I installed these on a 2011,2012, and 2015 and they all have some gap, yours doesn't look too bad, make sure to torgue the mounting bolts to spec as well
