OEM roof rack problem?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by spencer82, Dec 6, 2016.
  1. Jan 24, 2017 at 4:15 PM
    fiveofun
    fiveofun Active Member
    Kevin
    2017 TRD ORDC 4X4 Quicksand
    Stock
    I believe the Load Warrior will only fit with the extension. I have a Mega Warrior and mine will also only fit with an extension, however that is way too big for a Tacoma
  2. Jan 30, 2017 at 7:07 PM
    JH Taco
    JH Taco Well-Known Member
    2016 Tacoma TRD Sport - Inferno
    The gap is caused by the front tab of the mounting plate not being low enough. I was warned about this BEFORE the install, and got that part right. HOWEVER, I did not get the bolts PERFECT (cross-threaded one), and got wet seatbelts. By the time I swallowed my pride and took it to the dealer, the whole headliner had a sheet of water threatening to short out the air bags, etc. I had them dry it out for three days and reinstall the damned rack, and it has been perfect. You can do it yourself, but the install and bolt threading must be perfect! Wet seat belts are an early sign of IMPENDING PROBLEMS!
    "Ass-bitten by the Damned Rack..."
  3. Jan 31, 2017 at 3:05 AM
    mthopton
    mthopton Well-Known Member
    ‘03 TRD Prerunner, ‘16 TRD DCSB 4x4 - gone, 24 TRD OffRoad
    I pushed down the forward bracket tabs until they were almost touching the bottom of the ditch before installing the actual rack. Even then, I still have a slight gap at the highest point of the arc in the rack where it does not sit flush on the roof. No amount of adjustment or even pounding would let it sit flat. Perhaps taking off the yellow push pins would work. It is this way, equally, on both sides.
    Any suggestions?
  4. Mar 16, 2017 at 10:29 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Did everything work out ok, no issues since?
  5. Mar 17, 2017 at 4:18 AM
    capequahog
    capequahog Well-Known Member
    Cape Cod MA
    17TacomaDblCabTRDSport
    in the dreaded black
    am dealing with leak problem now with dealer, their body shop is looking at it next week, wet seat belts big time after storm, I believe it was a bad install with the screws washers etc myself, dealer installed
  6. Jul 10, 2017 at 8:41 AM
    cashjm01
    cashjm01 Member
    Joel
    2017 TRD OR Silver
    I installed myself this weekend on a 2017. First of all, it was a real pain in the ass to install. I had a difficult time with the either front or rear bolts not lining up once the opposite end were in. Very odd seeing as this rack is OEM. Outside of that, I'm not exactly happy about the play in the cross bars. With my kayak rack attached they have an awful lot of play moving back and forth. Almost to the point of me feeling constantly unsafe with kayak on top. Anyone else have this issue? Am I just paranoid?
  7. Jul 10, 2017 at 8:51 AM
    cabo wabo
    cabo wabo Well-Known Member
    billy
    virginia
    2019 dbc short bed trd sport
    Mine has a small gap on the drivers side with no issues. Installed spring of 2016.
  8. Jul 11, 2017 at 1:58 PM
    capequahog
    Cape Cod MA
    There should be no play in the crossbars, do you have them locked in correctly on the non pivot side, they kind of pop into a lock position as I recall.
  9. Jul 11, 2017 at 2:01 PM
    Radar
    Radar Member
    Doug
    2017 Toyota Tacoma TRD Sport 4 Door Long Bed
    Grills, Chrome Rings, Emblems, Wheel Flares, Wheels- All Black Now
    Put a set of OEM Racks on my Tacoma. Used the washers and used marine grade sealant. No Problems to date.
    shakerhood likes this.
  10. Jul 20, 2017 at 1:53 PM
    tucsat
    tucsat Member
    Salt Lake City
    2017 Red TRD Off Road Double Cab
    Nothing... yet
    Chalk up on more with a leaking roof due to the rack. Installed it myself but one of the screws or gasket washers on the drivers side is leaking. I now have a mildew smelling seat belt on truck that's a month old... FML
