OEM Roof rack (PT278-35170) on 2016?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco_Craig, Apr 13, 2018.
  1. Apr 13, 2018 at 10:26 AM
    Taco_Craig
    Taco_Craig [OP] Well-Known Member
    Craig
    2016 MGM Tacoma, DCSB TRD-OR
    RCI Sliders/Plates, Icon [Stage 3] Suspension
    I'm looking to install an OEM rack on my 2016 DCSB OR. On all the parts sites, the factory roof rack (PT278-35170) says it only fits 2017+. That surprises me a little, so I'm wondering if it's correct.
    Has anyone installed this exact part # on a 2016? Any issues? If not, which one should I buy instead?
    (I'm currently not looking for a better rack. This is just a stopgap measure so I can make use of my Yakima cargo box for road trips with the family. Eventually I'll get around to a better one, but that's probably a couple years off)
    For the record, I did make use of the Searches and the Googles before asking, but haven't found a definitive answer...
    Thanks in advance!
    [picture for reference, or something]
    -Craig
  2. Apr 13, 2018 at 10:29 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Hey Craig, does Tweek have a taco too?
    And for your question I don't know, Ive been looking at prinsu racks
    Technique and jeremy5000 like this.
  3. Apr 13, 2018 at 10:36 AM
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    OEM roof rack should fit all 2nd and 3rd gens. Same exact mounting locations. If they made an update to the part the 17 version will fit your 16 fine. No changes to roofs in 3rd gens.
    Be sure to silicone seal the thread mounts very well. There's been many complaints about the included washers not sealing it up and causing major leaks into the cabin.
    Also be sure that the rack has enough weight capacity for your needs. I'm not sure the numbers but it's not as high as the aftermarkets.
    SOLID, 2016Tacoman and Taco_Craig[OP] like this.
  4. Apr 13, 2018 at 10:47 AM
    Taco_Craig
    Craig
    He got a Ridgeline.
    jeremy5000 and Anchovy[QUOTED] like this.
  5. Apr 13, 2018 at 10:50 AM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    It will fit 2005-2018.
    Jeff
    tomwil and Taco_Craig[OP] like this.
  6. Apr 13, 2018 at 10:50 AM
    JonathanH
    JonathanH Well-Known Member
    Jonathan
    Southern Maryland
    11' DCLB
    Taco_Craig[OP] likes this.
  7. Apr 13, 2018 at 10:57 AM
    Taco_Craig
    Craig
    Awesome, thanks. This is more or less what I thought, but nothing's worse than discovering a problem in the middle of the install.
    Good advice. After your comment and everything else I've read, I'm going to make liberal use of silicone.
    It's definitely a little under what I'll eventually get (~100 lbs or so). Right now, I just need the option of throwing my box on the roof when I've got two boys and a wife in the cab. Normally I throw all my gear in the bed (or the backseat), but the wife is more protective of her bags and jackets and such. This just gives me breathing room and a cab that's not packed full of crap on long drives.
    Rob Daman[QUOTED] likes this.
  8. Apr 13, 2018 at 11:14 AM
    Loudog504
    Loudog504 Well-Known Member
    Luis
    Baton Rouge, LA
    2017 Tacoma TRD Off-Road 4X4 DCLB
    Should fit. But to be honest if you want functionality now or down the road save a few more bucks and get a real rack. I regret not doing the same. Just my two cents.
    jeremy5000 and STexaslovestacos like this.
  9. Apr 13, 2018 at 11:52 AM
    STexaslovestacos
    STexaslovestacos Well-Known Member
    Sam
    2017 MT TRD OR
    It will fit, but for how much it costs I'd just buy a proper rack. The OEM rack is only rated for 75lbs.
  10. Apr 13, 2018 at 12:39 PM
    Jeff Lange
    Calgary, Canada
    100 lbs, but the point stands, lol.
    Jeff
  11. Apr 13, 2018 at 12:52 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Sounds like something Tweek would buy!
  12. Apr 19, 2018 at 6:54 AM
    Sealanes
    Sealanes New Member
    Kelly
    2017 Tacoma TRD OR DCSB
    Had oem rack installed by dealer at delivery. Discovered my Thule Force LE cargo box will not fit. According to web sites for Thule and Yakima there is no cargo box that will fit. Looking into putting basket on top. Also discovered prone to leak into cab. Fortunately dealer resealed with no new leaks.
  13. Apr 19, 2018 at 7:06 AM
    Loudog504
    Luis
    Baton Rouge, LA
    No leaking on mine with a self install but yeah. The rack is pretty much for looks IMO. You can get some function out of it but in the long term and the price you pay for it you are better served to save a few bucks more and get a better option.
    Sealanes likes this.
  14. Apr 19, 2018 at 7:10 AM
    Sealanes
    Sealanes New Member
    Kelly
    Agree. Had I only known!
  15. Apr 21, 2018 at 12:07 PM
    EnviroJunkie
    EnviroJunkie Well-Known Member
    Cody
    Spokane, WA
    '17 Tacoma DCLB TRD OR
    Anyone here that installed an OEM rack want to sell the drip molding removed in the process???
  16. Apr 21, 2018 at 1:40 PM
    strktly_bodysurf
    strktly_bodysurf Well-Known Member
    You mean the weather strips that go in the roof gutter?
  17. Apr 21, 2018 at 1:46 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Same here, took my time, followed instructions and torqued to spec, no issues. I actually use mine for attaching the awning of my RTT on that side, so mildly functional for me. Also hauled a couple bikes once when we had 5 (2 on roof, 2 on hitch rack, one thrown in the bed).
  18. Apr 21, 2018 at 1:59 PM
    EnviroJunkie
    Cody
    Spokane, WA
    Yes. For whatever reason the Toyata part number lists them as "drip moldings" rather than gutter weather strips.
  19. Apr 21, 2018 at 2:09 PM
    strktly_bodysurf
    Honestly if you pay for shipping from Hawaii, which shouldn't be bad because I can roll them up and put them in a flat rate box, I'll give them to you for free.
    Not sure how much they are brand new so depending on whatever the shipping would be you'd have to decide if it's cheaper.
  20. Apr 21, 2018 at 2:37 PM
    EnviroJunkie
    Cody
    Spokane, WA
    That would be perfect... Looking at installing a RinoRack RTS track with Yakima towers and crossbars to the cab for the boats because I'm gonna dedicate the bed rack for a rooftop tent for the summer. The weather stripping will be cut to bridge the tip and tail seams of the tracks.
    PM me with a way to send you some moneys for shipping???
