OEM Roof Rack question...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thebaker, Jun 17, 2011.
  1. Jun 17, 2011 at 2:15 AM
    thebaker
    thebaker [OP] Well-Known Member
    Byron
    NorCal
    Upgraded to a 3rd gen
    Never ending......$$$
    I'm think about getting the oem roof rack for my truck. I will be using it to mainly carry my snowboards during the winter. i know the oem rack has the crossbars that can be folded when not in use.
    My question is can the rack be used with the cross bars in the stored position?
    I have some yakima mounts and cross bars that i usd on my previous suv. The mounts are made to grab onto the factory racks. I also want to be able to do this so i can adjust how close i can mount my snowboard rack together. I like to have my snowboard racks as close to my bindings as possible for security reasons.
  2. Jun 17, 2011 at 7:40 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    im pretty sure that you can put some aftermarket cross bars on the OEM rack. it certainly looks like it anyway
  3. Jun 17, 2011 at 6:15 PM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    I beleive it might be a tight fit if you try to fit mounts while the OEM roof rack is in the storage position. Lets see if someone with experience with the yakima mounts chimes in.
  4. Jun 17, 2011 at 10:25 PM
    thebaker
    Byron
    NorCal
    yuma,
    when the crossbars are in the stored position, are they secure? do they somehow lock into place?
  5. Jun 17, 2011 at 10:33 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    they lock securely
