OEM Roof Rack vs Something Else
Discussion in '3rd Gen. Tacomas (2016-2023)' started by phdog, Jul 31, 2017.
  1. Jul 31, 2017 at 1:09 PM
    phdog
    phdog [OP] Well-Known Member
    Jim
    Northern Colorado
    2017 TRD Off Road
    w/Super Terrific Happy Hour Mod
    Curious who has the OEM rack and how it's working for you? I like that it's slimmer and stows out of the way, but also seems to have a lower weight limit than a Yakima or Thule. Although also a lot cheaper than buying all those rack parts and towers. Maybe 100 lbs is enough.
  2. Jul 31, 2017 at 9:09 PM
    aaen
    aaen Well-Known Member
    Northern Alberta
    2016 DCLB 4x4 TRD Sport BBP
    Kings, ARB Summit Bumper, SMittybilt Winch, vagabond Drifter, Prinsu Cabrac, Crusinoffroad slidersand rear bumper
    I had it, hated it. never used it once. Just liked the way it looked on the truck. Ditch it and buy a prinsu, they look great, are functional and are fairly well priced.
    Now I am accessorizing my roof rack, and doing a few other mods to get things going on that for camping/etc. Cannot wait. Oh and I use it as a rook rack for storing stuff on when I go out in the back country.
  3. Jul 31, 2017 at 9:14 PM
    TejasTaco
    TejasTaco Grab a taco
    What are you going to put on the rack?
  4. Jul 31, 2017 at 9:42 PM
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    Go prinsu,
    #no regrets.
    Lord Helmet and rhipp like this.
  5. Jul 31, 2017 at 9:53 PM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    I have one of those rooftop cargo boxes. I try to stuff light stuff in there like sleeping bags, tent and other fairly light stuff but the box itself is 20 lbs or so as well. I think a Yakima or similar is rated around 150 lbs and I like a margin of error.
  6. Jul 31, 2017 at 10:06 PM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    That seems a pretty serious rack, but also looks more or less permanent. OEM rails would be too, but they fold out of the way when not used.
  7. Aug 1, 2017 at 7:02 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    I use the Yakima system and have had good luck with it. Easy on and off. Mileage will take a hit if you leave it on when you don't need it.
    G.
  8. Aug 1, 2017 at 7:13 AM
    Governor
    Governor Well-Known Member
    Las Cruces, NM
    2016 DCSB TRD OR 4x4
    I just bought a FrontRunner in a group buy for $755 shipped and will arrive Aug 2. The Prinsu looks the best but followed the lead of another member that has owned both and the FR is quieter. I also cared more for the FR based on the installation instruction and it appears it will be a little cleaner on the top rails of the roof. A must was something that would hold my big arse by standing on it and low profile to the extent that it would fit beneath a standard garage door entry, and both will do that.
  9. Aug 1, 2017 at 7:19 AM
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
  10. Aug 1, 2017 at 9:02 AM
    Jaque8
    Jaque8 Well-Known Member
    2017 Inferno TRD OR
    I've had the OEM rack on both of my 2nd Gens and my third gen. I love it and works great but fully understand its limitations. So I guess it depends on what you're using it for. I use mine exclusively to carry surf boards and snowboards/skis. Works great for what I need it for, looks better than the aftermarket ones IMO and from my experience its the quietest, can't even hear it at all on the freeway when the rails at stowed away.
    Also can't beat the price I get them for $300 from my local dealer.
    But if you're planning on loading it up with actual gear I think you'll quickly pass the 100lb load limitation. I've put 120ish pounds up there and offroaded through Baja with it and did just fine, but if you were going to be running 100+lbs regularly I'd probably get a Prinsu, my typical roof load is only 50-80lbs
  11. Aug 1, 2017 at 11:31 AM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    Thanks for the info. The rhino rack looks pretty cool but don't like that you have to drill holes in the roof. The clip on style seem similar to Yakima. I think I'm inclined to just go with the OEM rack or Yakima type as either should hold what I need.
  12. Aug 1, 2017 at 11:34 AM
    Comb
    Comb Known Member
    Oh, sorry, I didn't realize it required drilling. I assumed it used the same holes as the factory rack.
  13. Aug 1, 2017 at 11:46 AM
    Daver90s
    Daver90s Well-Known Member
    Hudson Valley NY
    '17 TRD Sport 4X4
    My wallet is empty
    Has anyone had an issue with the OEM racks leaking?
  14. Aug 1, 2017 at 11:49 AM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    Yes, I got that musky water smell when it rained from that rack. I need to clean it out now
  15. Aug 1, 2017 at 11:55 AM
    Oreo Cat
    I personally hate it. It's made from cheap plastic and didn't fit to my roof right without hours of wrestling it. Not worth the $250 I paid, all the bolts holding it on were rusted after 6 months of driving (in ca desert), also chipped the paint and put a big dent (both sides same spot) where it covered the roof. Yakima crossbars with a basket on the camper shell is loud and kills gas. Do it right the first time and get a prinsu or front runner unless it's only for looks
    Lord Helmet likes this.
  16. Aug 1, 2017 at 11:59 AM
    old55guy
    old55guy Well-Known Member
    mike
    2011 dcsb trd white
    none
    Got mine on a group buy , Last year , I"ve used it four times already , who needs a long bed , Prinsu
    betoman, Lord Helmet and EL_INGE2017 like this.
  17. Aug 1, 2017 at 3:01 PM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    Not sure who would put on a rack for looks. It's for when I need to carry stuff up there and save room in the bed. Obviously a rack and the stuff up there isn't good for gas mileage but that's why I want something removable or stow-able. The prinsu rack looks it would hold a VW, but I certainly don't want a giant rack up there for daily driving and it doesn't seem like a pop-it-on-when-you-neet-it rack. If the factory rack is cheaply made and not all that useful then I think a yakima or thule is probably best for my needs - clamp on when needed and remove when not. Thanks again for all the feedback. Helps me work through the options and what will be best for me.
  18. Aug 1, 2017 at 6:52 PM
    whitecord
    whitecord Well-Known Member
    dcsb trd off-road mt
    so how well do these racks work with the xm antenna in the shark fin? i have found that my oem rack folded out blocks the signal depending on the direction of travel. I like the oem rack for what i use it for but it isn't very sturdy. If i put both of my 14 foot racing paddle boards on it they move around a lot since the bar isn't very well secured.
  19. Aug 1, 2017 at 6:53 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    x3 Prinsu :thumbsup:
    EL_INGE2017 likes this.
  20. Aug 1, 2017 at 7:07 PM
    youngsurfrat
    youngsurfrat Well-Known Member
    Sullivan Ny
    2017 Tacoma TRD Sport
    Ive had thule yakima and now a factory roof rack. Really depends what you need it for. I only run fishing rods on mine currently, so i like the fact that theres nothing in my door jam (the "feet" of your standard thule/yakima rack) Scratching the paint, and causing damage to the door seal. With that being said i ran a factory set of yakima/thule on my ARE cap for kayaks. But those didnt effect any doors. Again depends what you plan on putting on your roofrack. Obviously cant use the factory bars and mount an RTT to it... theres a trade off with everything
