OEM Running Boards PT212-35053
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hillbillynwv, Jan 9, 2019.
  1. Jan 9, 2019 at 8:36 AM
    hillbillynwv
    hillbillynwv [OP] Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    This weekend I will be getting a used set of these for my 08 Access Cab. The owner does not have the hardware to attach these. I know I need 3 bolts per side, anyone here have any idea the diameter and lengths of these bolts??
  2. Jan 9, 2019 at 8:52 AM
    Kimgt
    Kimgt Well-Known Member
    Kim
    Fullerton, CA
    2012 Tacoma DCLB
    Stock
  3. Jan 9, 2019 at 9:43 AM
    redcon
    redcon Well-Known Member
    Dave
    Southern PA
    2012 AC 4x4 Base 2.7L/5MT
    Damn I would love to find a set of those used. They look so much better than the tube steps IMO. What did you guys pay for them?
  4. Jan 9, 2019 at 9:44 AM
    hillbillynwv
    Fairmont, WV
    Thank you very much for all of that information.
  5. Jan 9, 2019 at 9:54 AM
    Kimgt
    Kim
    Fullerton, CA
    2012 Tacoma DCLB
    Stock
    It looks like you can get a set for around $200-250 new online, just punch in the OEM part number into your search bar and see what pops up.
    They look nice because they're tight to the body and have a finished look, as opposed to tubes. some cons: very tight to the body so you only really use the outer half of the step and the fascia is plastic so its not very grippy. it could use some grip tape
  6. Jan 9, 2019 at 6:27 PM
    I.am.broccoli
    I.am.broccoli Member
    Brock
    2008 TRD SPORT
    Na
    What's the OEM part #?
  7. Jan 9, 2019 at 6:30 PM
    Kimgt
    Kim
    Fullerton, CA
    2012 Tacoma DCLB
    Stock
    It's in the thread title
  8. Jan 9, 2019 at 7:37 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    The Access Cab ones are a bit harder to find as they're less common than the Double Cab ones. I bought my Double Cap set from a member here for $100. I would think you could source a used set somewhere int he $120-150 range quite easily if you don't need to purchase new ones.
  9. Jan 10, 2019 at 11:21 AM
    hillbillynwv
    Fairmont, WV
    i
    I am getting the set for $80 bucks, but I do have to drive an hour to get them.
  10. Jan 17, 2019 at 1:43 PM
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    Here's mine!
    Estephe21 likes this.
