OEM running boards
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jpmorrisvb, Sep 21, 2014.
  1. Oct 3, 2014 at 9:39 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    I had chrome steps and hated them. I went with some Avid light duty sliders that bolted to the step holes because I couldn't bring myself to weld or drill new holes through my frame. 42dd211bd96b42753dd26a19b20655af_b7c72e22e79a718122953d49ea689bf7ad27608d.jpg
  2. Nov 5, 2014 at 1:45 PM
    heckeng
    heckeng Active Member
    Jared, do you actually use the steps to get in and out or are they just in the way? I have the stock running boards which I love the looks of, and love that they protect the side of the truck so well but they make getting in and out a bit of a pain in the ass. I like the looks of yours, they seem well built, subtle, but useful. Do you think they protect the sides of the truck from dings or debris from the tires much?
