OEM Shock replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by Shikkapow, Jan 14, 2010.
  1. Jan 14, 2010 at 1:02 PM
    Shikkapow
    Shikkapow [OP] Active Member
    Sunny Florida
    01 sr5 4x4
    I posted in the wrong forum earlier
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/69738-diy-2001-shock-replacement-help.html
    And figured I might get the correct coverage here when it comes to replacement shocks.
    Daily driver 2.7Ltr, minimal off road, stock height truck. I want to pretty much replace what I have.
    Any particular brand I should avoid? I am away from home and unless I can get it by Saturday I have to rely on a auto parts store. I know they stock Rancho's and other brands at Advance auto.
    Im a dumbass for waiting since I knew I would be in VA, and once I go back to LA, I wont have the time or the tools to do it and it'll run me $$$ to have someone else do it.
    Any thoughts on brands/ models?
    I found Gabriels in stock, but never heard of them
    Front
    http://www.autozone.com/autozone/ca...splayName=Suspension+&+Steering&parentId=46-0
    Rear
    http://www.autozone.com/autozone/catalog/parts/partsProduct.jsp?itemIdentifier=228544_0_7413_&skuDescription=Gabriel+Ultra+/+Shock/Strut+-+Rear&brandName=Gabriel+Ultra&displayName=Shock/Strut+-+Rear&categoryNValue=&sortType=&store=1040&isSearchByPartNumber=&fromWhere=&fromString=&counter=2&itemId=661-0&navValue=14600661&filterByKeyWord=&productId=228544&searchText=&categoryDisplayName=Suspension+%26+Steering&parentId=46-0
    I also found some KYB's and I have heard some decent things about them
    Thanks!
  2. Jan 14, 2010 at 2:56 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Actually, when I lifted my Dodge Power Wagon 30 some years ago, the lift kit was from a new company called "Rancho" (you may have heard of them) & their still around, it came with 4 Gabriel Racing adjustable "E" series shocks (I added 4 more later I liked them so much) So I can vouche for them, KYB's are good, I think they were the first Gas charged positive/negative dampening shocks on the market, but may I ask why not OEM Bilstiens ? Since you want to just replace them. Stay away from Monroe (if they are still around) Always was a weak shock with a pretty wrapper to hide the shitty valve dampening rod not to mention they had the crappiest seals in the buisiness. Back in the day, you pretty much had 2 choices for susp. kits & shocks, the Rancho was my choice because the other one was from "Dick-watch-it-break" Cepek & the Rough Country brand that looked awesome (All pretty with gloss black & yellow shock tubes, but don't confuse it with a Bilstien because of the color) The Rough country shock was great for the first few times out but like clockwork,the first time they really had a little work out, I swear there wasn't one around that didn't blow the seals & slobber & drool Hydraulic fluid all over hell, leaving your rig to bounce around like a fucking pogo stick ,the springs were waaay to soft & wouldn't hold an arc either & contrary to what some say THE ROUGH COUNTRY SHOCK WAS NOTHING MORE THAN A MONROE SHOCK minus the dust shield w/an inferior valve body, plus was way more expensive than the Rancho susp lift & a hell of a lot weaker in design.....go with the OEM BILLY's they're not that expensive & Bilstiens have proven themselves.... Just my opinion Bro'.....:cool:
    :mudding:
  3. Jan 14, 2010 at 4:21 PM
    Shikkapow
    Sunny Florida
    01 sr5 4x4
    ranchos.. i think Ive heard of them. :)
    probably going to go that route
    thanks!
  4. Jan 14, 2010 at 4:59 PM
    gusotto
    gusotto gusotto
    Gary
    Iowa
    2001 Tacoma 4X4 SR5 Extended Cab
    Lots of choices but I am having the stock shocks (F/R) during my frame swap because if the dealer does it, future parts and labor is free.
  5. Jan 15, 2010 at 12:09 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Avoid the KYB Monomax shocks like the plague, they ride as stiff as hell, you'll feel every little bump on the road. Had those on for 2 weeks and couldn't stand them. Got the Bilstein HD shocks.... much better ride.
  6. Jan 15, 2010 at 5:49 AM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    Get billys
  7. Jan 15, 2010 at 8:17 AM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    Yup. Bilsteins. Great shocks.
  8. Jan 15, 2010 at 8:20 AM
    kingston73
    kingston73 Well-Known Member
    eastern MA
    09 SR5 4.0L 4x4
    I guess it all depends on what you're after, I purposely got the Mono's because I wanted a tighter ride. I like em!
  9. Jan 15, 2010 at 8:43 AM
    You
    You Junior Mint
    I have the Bilsteins and they are a bit stiffer than stock ( set at the highest setting). How much "tighter" are the KYB Monomax than Bilstein?
  10. Jan 15, 2010 at 8:47 AM
    kingston73
    eastern MA
    09 SR5 4.0L 4x4
    I had the HD's before this, replaced them at 4 years. I can't say what the difference between new HD's and new Mono's is because I can't remember what my HD's were like new, but the Mono's are good for me. Possibly because I have a cap on the back and carry around close to 300lbs all the time, so I can see them being maybe too stiff for an unloaded bed.
  11. Jan 15, 2010 at 8:54 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I'm comparing the Billy HDs to the KYB Monomax shocks and the KYBs are VERY STIFF. The Billys ride like a Cadillac compared to the KYBs.
    Mush Mouse likes this.
