OEM "Skid Plate"
Discussion in '2nd Gen. Tacomas (2005-2015)' started by danteisme, Nov 8, 2011.
  1. Nov 8, 2011 at 4:50 AM
    danteisme
    danteisme [OP] Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    ok, you guys with the second gen 2.7s answer me something. why in the hell is the oil filter pointed straight down ontop of the "skid plate"? stupid...
    anyway, i'm not sure if i'm the only one that does this but when i change my oil i remove the skid plate that is directly under the front diff and the oil filter. just so that way when oil comes running down, it doesnt just sit on top of that skid and run all over later on. yesterday i was changing my oil. went to remove the 2 front bolts (the ones that are set up in) and of course with my luck they snapped off. so i continue with my oil change and wait until i'm finished to try and fix the problem. i tried using my screw extractor and that failed. so i started grabbing drill bits. luckily those factory bolts are soft metal. drilled right up through them in no time. one side worked fine, the other however now has a portion of my drill bit stuck up inside there too. i'm still left with some of the bolt in the threads and can't get a new bolt in on the other side. i hate this....i'm not entirely sure if i need all 4 bolts to hold that skid up there, i see it has the metal tabs that extend over in the front. maybe just that and the 2 bolts in the rear is enough? thoughts, help?
    also, i'm sitting at my desk at work and its entirely too early...if something doesnt make sense in what i just typed i blame it on my lack of coffee at 745 am.
  2. Nov 8, 2011 at 4:59 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    Considering that my 98 with the 3.4 has exactly the same issue you would think that by 2005 Toyota would have figured out how to put an oil filter on an engine that doesn't leak all over when you change it(see GM 350 or 454). As to your Skid plate issue you will probably have to either find another way to fasten the skid plate where that bolt is broken(will rattle like crazy I imagine) or get a high end drill bit and clean out the hole completely and rethread it.
  3. Nov 8, 2011 at 6:11 AM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Drill out the snapped bolt and tap the threads. Could try to easy out the bolt just don't snap it off. When that happens the fun begins.
  4. Nov 8, 2011 at 6:46 AM
    danteisme
    South Western PA
    yeah i think i may end up having to drill a hair bigger and then re thread it.
