OEM sourced rear shock to use with dakar springs
Discussion in 'Suspension' started by 65skyturbo, Aug 30, 2017.
  1. Aug 30, 2017 at 9:01 AM
    65skyturbo
    65skyturbo [OP] Well-Known Member
    Mesa, AZ
    06 Speedway Blue DCSB TRD Off Road
    As the title states, I'm looking for a rear shock that is normally used on a different truck but happens to fit the Tacoma. F-150, Ram, Silverado, Tundra, Titan, etc. I'm thinking about getting some Fox shocks (no reservoir) but they only have it listed on the Tacoma for 1" over stock. If a Silverado just happens to be the same mounting style and is 3" longer than a Tacoma it would work out perfectly. Any ideas? Thanks.
  2. Aug 30, 2017 at 9:02 PM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    @Wheeler's Off-Road Inc sells a fox 2.0 rear shock with no resi for 0-2" lift. Allpro also has another part number on their site that says up to 3" I believe. I can't remember but I think they fit other Toyota models, like 4Runner or FJ's, so they should bolt right up.
  3. Aug 30, 2017 at 9:46 PM
    65skyturbo
    Mesa, AZ
    Yep, just found that on All Pro's website. FJ Cruiser and 4runner rear shocks. Also 1997 - 2004 Ford F150 2wd rear shocks are the same....
  4. Aug 31, 2017 at 8:42 AM
    Wheeler's Off-Road Inc Well-Known Member
    Grants Pass, OR
    We usually recommend for the Dakars:
    OME: Bilstein 5100: Bilstein 5160's: Icon The extended length on the OME shocks are 23.93" and are meant to work with the Dakars. The Fox shocks that we carry have an extended length of 23.55" which is just slightly shorter. So just barely out of the ballpark of working no problem. If you carried constant weight on the Dakars, it would be a for sure option since you are not at the max lift heights of those leaf springs.
    *Be careful of the valving of shocks meant for bigger sized trucks. It may be the same and could work out perfectly. BUT be for certain or your Tacoma will/could ride like a dump truck.
  5. Aug 31, 2017 at 9:38 PM
    65skyturbo
    Mesa, AZ
    Yeah, ride quality was definitely a concern with using a shock designed for a full size truck. But that's assuming the manufacturer actually changes the valving for each application and not just the length & mounting styles....
  6. Sep 18, 2017 at 10:26 AM
    CamShaft033
    CamShaft033 Well-Known Member
    Cameron
    Chattanooga TN
    2012 DCSB TRD Sport
    OME 887s, JBA uca, Dakars, Fox Shocks, 285/70/17 Nittos, Dual Flowmaster, ARE Camper Shell w Yakima Rack, CVT Tent, AVID Rear Bumper Guard w LED Pods, 52" Lightbar, Sportsman Seat Covers, WeatherTech Floor mats
    SKU: FOX-980-24-679
    2.0 Performance Series, Internal Floating Piston (IFP), Non-Reservoir shock for 0-3″ lift. Fits Toyota 03+ 4Runner, 05+ Tacoma, and 07+ FJ Cruiser.
    These will work I just ordered a set to go with my dakars.
    Hope this helps. I was in the same boat.
