OEM Speakers
Discussion in 'Audio & Video' started by tommyxv, Sep 30, 2010.
  1. Sep 30, 2010 at 2:01 AM
    tommyxv
    tommyxv [OP] Well-Known Member
    Delaware
    '11 DC 4x4 TRD Sport
    Looking to replace the factory speakers when I go to do my Z-120BT install next week. No Amp and no Sub for this install. Just want quality speakers that are easy to swap in. The factory ones are already distorting and the volume sucks.
    What size speakers do we have? For the life of me, I cannot find the OEM sizes for the 6 speaker non JBL system. LOL 6 1/2" in all 4 doors??
  2. Sep 30, 2010 at 8:22 AM
    GT_Taco
    GT_Taco Newbie here
    Marietta, GA
    2016 4Runner 4x4 Limited Metallic Gray
    5K LED interior lighting
    I am looking for BETTER info, but from everything I can find, it is a 6x9 in the front door with a tweeter higher up on the door, and 6.5s in the rear doors.
  3. Sep 30, 2010 at 8:32 AM
    tommyxv
    Delaware
    Thanks! Going to see what Crutchfield has for it. I guess what was confusing is that some are putting 6 1/2" in for the 6x9s.
  4. Sep 30, 2010 at 8:47 AM
    biasottw
    biasottw Member
    2010 V6 6-Speed TRD Offroad
    check out they have a lot of how to's as well as mounts that allow you to place any size speaker into the original mounts. Good luck.
  5. Sep 30, 2010 at 9:36 AM
    tommyxv
    Delaware
    Thanks
    Even if I am putting back the same size? Wonder is Crutchfield supplies them.
  6. Sep 30, 2010 at 9:46 AM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    OEM are 6X9" and a component tweeter up front, 6.5" in the rear. The OEMs have a built on speaker adapter so you'll have to get aftermarket adapters to put on your speakers. Personally I went with 6.5" in all four doors (just buy the appropriate adapters). I bought mine on eBay for about $20, remember they're just adapters you don't need to spend a lot on them.
  7. Sep 30, 2010 at 10:52 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    The factory speakers are a 6x9 and the rears are 6.5s.
    In either case you will need speaker brackets to make them fit (and be mountable)the the hole in your door is actually bigger then a typical 6x9. You will also need speaker brackets/rings to clear your windows when they are in the down position.
    I would recomment a set of 6.5" component speakers for the front as opposed to 6x9s, they are a bit better acoustically because they are round and not oval in shape.
  8. Sep 30, 2010 at 10:57 AM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    im planning on replacing my explodes soon and was wondering what the difference is between 2-way, 3-way, component etc. is? which one is best? i dont remember what my explodes are, i just bought them cause they were cheap and sounded good.
  9. Sep 30, 2010 at 11:15 AM
    Tacomanator
    Clam Slammer
    Southern Cali
    thanks. so the more "ways" a speaker has the better it will sound? i saw speakers that go all the way up to 5-way on cruthfield.
  10. Sep 30, 2010 at 11:30 AM
    Asgard
    I would go with 2-way and upgrade later by adding a 8" or 10" sub. You're not going to get much bass from a 6.5" door speaker no matter the quality.
  11. Sep 30, 2010 at 11:49 AM
    Tacomanator
    Clam Slammer
    Southern Cali
    thanks for the info guys! ill just go with a good set of 3-way speakers. i dont really need to much bass out of them since i already have a 12" L5 kicker.
  12. Sep 30, 2010 at 1:40 PM
    tommyxv
    Delaware
    Thanks for the info. I was thinking of getting component 6.5" and component tweeter for the front doors and a 2-way 6.5 for the rear doors. I'll be using just the Pioneer AVIC Z-120BT, no amp or sub.
    I wonder why they used a 6x9.
  13. Sep 30, 2010 at 2:09 PM
    hookedontronics
    Jake
    Glenville, NY
    ^ good choice
  14. Sep 30, 2010 at 4:25 PM
    raswank
    raswank Well-Known Member
    Rick
    Auburn,Ma
    2010 Tacoma Double Cab 4x4 6 speed
    Grillcraft, Rear leaf TSB, 5100's at .85, with Eibachs, 265/70/17 BF Goodrich AT/S Tires, Hella 500's behind Grill, Kenwood KDC X995 H/U all Boston Acoustic speakers, JL Audio subs, Kenwood XR5 S amp, ATX Chrome 17x8 wheels
    i was thinking of some boston acoustic sr95's for the front and sr65's for the rear. what is the mounting depth i can go to without issues in the front with the 6x9's
  15. Sep 30, 2010 at 9:16 PM
    tommyxv
    Delaware
    TacoTunes.com says 3 1/4" Top mount depth.
  16. Oct 1, 2010 at 1:52 PM
    tommyxv
    Delaware
    Any suggestions for decent speakers to replace the factory ones? No amp, no sub, 4 x 15w RMS (50 peak) from the AVIC-120BT
  17. Oct 16, 2010 at 7:41 PM
    vr6pilot
    vr6pilot rather be dubbin'
    Dan
    Viva New Mexico!!
    2016 Quicksand SR5
    I just bought Infinity Reference 6x9's. Infinity makes great stuff, 6x9 for the largest cone, and a 94db sensitivity rating. The Kappas are rated at 96 db!!! but required more mounting depth. The ref's are louder than the stock spkrs even wired to the factory HU and the bass reproduction is much better controlled.
    Looking forward to my JVC XR810....coming tuesday!
  18. Dec 2, 2010 at 3:54 PM
    KodiakToyTRD
    KodiakToyTRD Well-Known Member
    CO
    2013 Scion FR-S Whiteout
    Did you guys get the adapters for the front and the back or just the front?...ebay has the options for the back, front and tweeters..
  19. Dec 2, 2010 at 4:05 PM
    KodiakToyTRD
    CO
  20. Dec 2, 2010 at 4:10 PM
    KodiakToyTRD
    CO
    I'm looking around, does scosche make an adapter for the rear like tacotunes does? Sorry about the questions, Toyota has me a little confused right now about why they did it this way.
    Edit: its looks like its gonna be the SAT6 for the rear and the SAT69 for the front if I have my info right.
