OEM Spring differences: DC, Access, Reg Cabs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by justinhw, May 15, 2011.
  1. May 15, 2011 at 10:48 PM
    justinhw
    justinhw [OP] Well-Known Member
    Turlock, CA
    06 Regular Cab 4x4 2TR-FE
    I've read here that the OEM spring rate for a DC is 540lbs/in. However, because there are weight differences in Regular, Access, and Double Cabs, does anyone know if spring differences are in length, rate, or both?
    It doesn't make intuitive sense to me that they all use the exact same spring.
    I would assume a similar length but different rate?
  2. May 16, 2011 at 7:58 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    That's a pretty general statement. There's a decent difference in weight between a Reg cab w/ 2.7L and a DCLB with a 4.0L... I'm curious to find out if they use a different set-up for these also.
  3. May 16, 2011 at 9:18 AM
    justinhw
    Turlock, CA
    Sorry not to clarify. I meant 4x4 versions.
    According to the toyota.com spec page, Curb weights (all 4x4, manual trans option):
    Regular cab 2.7L = 3665lbs
    Access cab 2.7L = 3955lbs
    Access cab 4.0L = 4045lbs
    Double cab 4.0L = 4130lbs
    Considering people are upgrading the suspension with the addition of a 110-160lb bumper, I'd assume there must be spring differences! Granted, a bumper is in front of the rear axle whereas engine/cab differences places weight either on top of the front or in between axles.
  4. May 16, 2011 at 10:50 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Might check the parts lists and see if there are part number differences between the models.
  5. May 16, 2011 at 1:08 PM
    justinhw
    Turlock, CA
    That's a good idea! I'm having trouble finding those lists, the closest thing I've found so far is this but they have no data for 2005+ trucks with regards to suspension. Any help locating a list would be appreciated
    I see what you mean, thanks. I have run into some threads about front suspension sag when adding something like an ARB bumper (like this). You do have a point in that a bumper places weight ahead of the front axle, whereas body/engine differences places weight in the center where the rear springs can help compensate for the additional weight. So there may very well be no differences (or very small differences) in the springs between models.
    Ultimately, what I would like to be able to do (if the springs are in fact significantly different) is add an ARB bumper (no winch) and use a spring from say, an access cab, to maintain stock ride height (I have a regular cab).
