OEM steering rack rebuild s
Discussion in '1st Gen. Tacomas (1995-2004)' started by manger, Jan 19, 2021.
  1. Jan 19, 2021 at 2:51 PM
    eon_blue
    Azusa, CA
    I recommend not messing with it unless you know it needs checked, it was a royal PITA to get mine in just the right setting again after I loosened and then tightened it. It's extremely sensitive to it's torque setting and you can really tell in the feel of the steering if it's not quite right. I still need to try to get it just right
    Sorry for the thread derail OP
  2. Jan 19, 2021 at 2:52 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    I just want a tiiiny bit tighter steering. So whacha think? 15 degrees tighter?
  3. Jan 19, 2021 at 2:54 PM
    eon_blue
    Azusa, CA
    honestly I would probably try to achieve that with an alignment rather than messing with the rack guide, but yeah only 15˚ if that if you do give it a try. If you get more caster added to your alignment it should tighten up the feel as well going into corners. Also having poly LCA bushings and poly steering rack bushings helps firm it up.
  4. Jan 19, 2021 at 2:58 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    I've got the poly steering rack bushings, but I've always felt this new one was loose compared to the factory rack. Can see what an alignment will do. Thanks
  5. Jan 19, 2021 at 10:07 PM
    daluvian
    daluvian Well-Known Member
    San Diego
    2005 Tacoma
    Long travel
    What I can tell you is this I’ve seen the remain racks from Toyota and the remain from Napa they appear to me to be remain by the same company not 100 percent sure but the packaging that the steering rack comes on is a flat cardboard box that is shrink wrapped was the same with the same little orange tag regarding flush, and same tie rod end boot clamps just a heads up. That was for second gen tho
    TWJLee likes this.
  6. Jan 19, 2021 at 11:26 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
  7. Jan 20, 2021 at 12:05 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    i dont think you can get a new rack from toyota anymore. just remans. when i got my new rack a few years back there were only a few left in the country.
  8. Jan 20, 2021 at 5:55 PM
    Nevin
    Nevin Well-Known Member
    Washington
    03 Tacoma 3.4 SR5 2022 TRD ORP 4Runner.
    OME 881 springs with 3/8 spacer. SCS SR8 16x8 Gunmetal 285/75/16 Yokohama G003 Nitros all 4 corners. Dakar rear leafs. Deckplate mod. Marlin Crawler 1200lb clutch. Redline hood struts. ECGS clam shell bearing. Philips LED headlights. Front Runner bed bars. Katskinz leather interior.
    I spoke with a dealer recently and the OEM reman part #44250-35042-84 and have a core charge of 150.00
    You can still get OEM racks with part #44250-35042
    Anyone have experience with this?
    TaliTank13 likes this.
  9. Jan 20, 2021 at 5:57 PM
    Empty_Lord
    Dan
    Well if the new racks are still available, snatch them up! They’re the best! Lol
  10. Mar 8, 2023 at 5:50 AM
    xcmtb83
    xcmtb83 Well-Known Member
    Iowa
    So who all has tackled this DIY? If the rack is leaking I think this is great solution. However, I don't see in here where this procedure addresses any gear lash between the rack and pinion. I assume there is generally always wear on the two components and the only way to remedy this is new parts of to be able to adjust the clearance between them. Did Toyota design any adjustability into this interface? TIA!
  11. Mar 8, 2023 at 7:06 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
  12. Mar 8, 2023 at 7:16 AM
    xcmtb83
    Iowa
    No, that isn't what I am asking about but that is a must-do mod even for un-lifted vehicles that use this steering rack.
    I am referring to the gear lash. The interface between the round gear at the end of the column where it meets the geared shaft. Much like a differential this interface is critical to a proper fit, free of excessive slop/play/clearance/gear lash or any other synonym that suits your fancy. In this writeup I didn't notice a method to mitigate wear on these components. I am all about saving money so I like the idea of this rebuild but if I go through with it and still end up with play in my steering system it was a waste of time.
  13. Mar 8, 2023 at 7:58 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I never explored that option but I understand what your talking about.
    A very valid question.
    Have you looked if those parts can be bought new ?
  14. Mar 8, 2023 at 10:35 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Gear lash between the rack and the pinion gear is zero.
    The rack guide has two functions. The curved shape of the guide itself prevents up and down movement of the rack shaft. The "cap and spring" prevent front to back movement of the shaft and keep it pressed (preloaded) against the pinion gear, constant zero lash. The cap is sometimes known as the "preload adjuster".
    https://www.tacomaworld.com/threads/rack-pinion-service-tools-tips.312600/#post-8072827
    Bivouac and xcmtb83[QUOTED] like this.
