OEM tailgate backup camera retro questions??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yosh2000, Aug 15, 2010.
  1. Aug 15, 2010 at 9:48 PM
    yosh2000
    yosh2000 [OP] Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    quick question for all you that have added the OEM backup camera to your 05-08...(im doing the install on my 05)
    what line did you tap into for the power to the camera? schematics i received say its a 6v line? i was thinking of tapping from the reverse bulb power, therefore the camera will only be powered when i actually use it and am shifted in reverse...
    any help would be great, thanks guys!
  2. Mar 30, 2011 at 1:19 PM
    vietboytoan
    vietboytoan Member
    Phillip
    Houston, TX,
    07 PreRunner SR5 2WD Tow Package
    In Progress...
    I am assuming you have finished installing your camera by now but, I am currently doing this modification to my 07 truck. I am a bit lost on the process, but I just received my tailgate handle with camera in today. It did not come with a harness so I am trying to find out how to do all the wiring to my pioneer head unit. If you could, let me know what steps you took to install your camera and what you hooked it up to. Any information would be helpful at this point.
    Thanks!
  3. Mar 30, 2011 at 3:12 PM
    tarandus
    tarandus Well-Known Member
    Montucky
    '17 TRD DCab OR Supah White
    ProComp/Headstrong leveling kit, AllPro rock sliders.
    where did you all pick up the OEM cameras? how much? Sounds like you're connecting to a new HU; any ideas about stock camera rearview mirrors? Thanks!
  4. Mar 30, 2011 at 4:47 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Your camera is composite video and should work with any monitor, your head unit most likely needs a + 12 volt input from the reverse lights to switch to monitor mode. The video cable is 75 ohm RG59 and the camera will run fine with #16 hook up wire. I have no ideal what kind of connector is at the camera end but the head unit most likely is a male RCA connector. My new Taco has a camera and I am not sure if it is powered on with the key or not I suspect it is because it comes up instantly cameras take some time to fully come on so I think it is powered with the key. It does not hurt a camera to stay on they will run 24/7 for years I have some in service that are close to 25 years old.
  5. Mar 31, 2011 at 12:26 PM
    vietboytoan
    vietboytoan Member
    Phillip
    Houston, TX,
    In Progress...
    found this on ebay for 150+shipping. It did not come with a harness so I am planning on just soldering cable to it and run everything myself to my head unit. I have been looking at many different forums and the video seems to look decent.
  6. Mar 31, 2011 at 9:31 PM
    Jerry Bear
    Jerry Bear Well-Known Member
    Jerry
    Mesquite, Texas
    2010 Access Cab
    tint, topper, receiver hitch, trailer wiring, topper lighting, cruise control, intermittent wipers, backup camera, auto-dim mirror
    The OEM camera is powered when the truck is put into reverse gear.
  7. Mar 31, 2011 at 11:35 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 Mid-Travel 4x4 DCSB 6spd
    Kings Mid Travel, BAMF bed rack, RTT, dual battery, OBA, ARB locker, 4.56 gears
  8. Apr 1, 2011 at 3:15 AM
    vietboytoan
    vietboytoan Member
    Phillip
    Houston, TX,
    In Progress...
    So will it be fine to run the power from the reverse light that is 12 volts? I am hearing that it takes 5-7 volts.
  9. Apr 1, 2011 at 3:16 AM
    vietboytoan
    vietboytoan Member
    Phillip
    Houston, TX,
    In Progress...
  10. Apr 1, 2011 at 4:11 AM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    I thought the camera was 6 volts???i wouldn't put 12 volts to it
  11. Apr 2, 2011 at 1:42 PM
    MJonaGS32
    MJ
    SF Bay Area (East)
