OEM Tailgate Lock Install / Frame Wiring Clips 2022 SR5
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dnelson200, Oct 30, 2022.
  1. Oct 30, 2022 at 3:25 AM
    dnelson200
    dnelson200 [OP] Active Member
    Darren
    2022 SR5 Double Cab Magnetic Gray Metallic
    I got the OEM tailgate lock installed on my 2022 SR5, which doesn’t have an existing wire loom to attach to as I ran the new wiring back to the tailgate. I was able to zip tie to the frame rail in various places back to the tailgate. I am sure that I will never have a problem with the setup as is but I would like a more factory-like way to secure this wiring to the frame. I was considering these clips from Amazon instead of zip ties to the frame. Any thoughts or better ideas!
    GOOACC 60Pcs Car Wire Loom Routing Clips Assortment - 6 Different Sizes Universal Wiring Harness Routing Clip Replacement Parts for Honda GM Mazda https://a.co/0UvQB17
  2. Oct 30, 2022 at 4:21 AM
    AtomAnt
    AtomAnt Well-Known Member
    Adam
    South Cackalacky
    2019 TRD Sport
    Don’t overthink it. No point in using anything other than zip ties.
    TexasWhiteIce likes this.
  3. Oct 30, 2022 at 4:47 AM
    stftaco
    stftaco Well-Known Member
    22 MGM DCSB Tacoma TRD Sport
    I wouldn't overthink it either, however, did you run the wiring through PVC wire loom tubing / conduit? Because of the exposure to harsh elements, I would think that would be infinitely more important than loom fasteners, although, those do look pretty slick. Note that one style of fastener is essentially a push-mount zip tie.
  4. Oct 30, 2022 at 8:17 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    If the OP got the OEM lock kit it comes with the wiring in a loom that is also heat shielded in spots to protect from the heat of the exhaust. If he went aftermarket I'm not sure if its the same. Either way, I agree protecting the wiring is important, and I would just use zip ties as they would give the most flexibility in choosing attachment points.
    EDIT: re-read the OP's post and he does in fact have the OEM lock kit so all should be good.
    stftaco[QUOTED] likes this.
  5. Oct 30, 2022 at 1:32 PM
    dnelson200
    Darren
    Yes, it is wrapped in the black plastic tube and the heat shielded section.
  6. Dec 18, 2022 at 2:45 PM
    cuser414
    cuser414 Well-Known Member
    2021 tacoma SR5
    Where did you put the zip ties on the SR5? I am running into he same issue and thought about going the same route for a factory like install, also I am having a hard time figuring out the best places to put the metal zip ties.
  7. Dec 19, 2022 at 5:25 AM
    dnelson200
    Darren
    I ended up using a small package of these type of zip tie mounts from Home Depot:
    https://smile.amazon.com/XHF-Back-G...refix=zip+tie+mount,aps,149&sr=8-1-spons&th=1
    I used the metal ties around the frame around the exhaust area. The metal ties aren't pretty or clean but it will hold things in place.
  8. Dec 19, 2022 at 8:33 AM
    dnelson200
    Darren
    It does but the SR5's don't have the wire loom running down toward the back of the truck to connect to. We have to find our own ways to tie the wires to the frame.
  9. Dec 19, 2022 at 9:30 AM
    cuser414
    2021 tacoma SR5
    Thanks. It's def not easy figuring out the best places for the zipties that's for sure. Clipped directly to the frame like it is on the drivers side would be the best route, but I couldn't find info on what clips those are. The clips I've found on Amazon are all way too small to fit in the frame holes.
