OEM tires okay to drive on beach?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Frankmig, Apr 21, 2016.
  1. Apr 21, 2016 at 5:43 PM
    Frankmig
    Frankmig [OP] Well-Known Member
    2019 4x4 DCSB TRD Sport Tacoma White
    Predator step up bars, Tonneau cover OEM
    Hello folks,
    I purchased my first Tacoma ever this past Jan. I will be in the Outer banks, NC this June and may drive on the beach. Of course I have 4X4, but I am worried my OEM tires that came on the truck may be an issue on the beach. They are 265, 65, 17 inch Firestone Destination LE2's. I was looking at getting a set of Bridgestone KO2's but they are $1,145 installed. They will only offer me up to $100 per trade in on my OEM tires, so I was hoping they may be good enough for beach driving until I need new tires. What is your experience and recommendation? Thank you for your input as I am new to 4X4's and Tacomas.
    By the way, the KO2's were 275, 65, 17. 10 mm wider than my factory tires. I was told they wouldn't have issues with rubbing, etc. on a stock 2016.
  2. Apr 21, 2016 at 5:45 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Anytime you drive on sand you need to air down to about 10-12 psi To get a bigger foot print and allow the tires to float not dig in and bury yourself to the frame
  3. Apr 21, 2016 at 5:48 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Just don't be a retard and drive in the ocean. No one wants to buy a used Tacoma that was soaked in salt water.
  4. Apr 21, 2016 at 5:50 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Check out discounttiredirect.com They ship for free. I got 4 General Grabber AT2s for $600 and another $100 to mount them. Then I turned around and sold my stock tires on CL for $300. My new tires kick ass in sand!
    Toy916 and Frankmig[OP] like this.
  5. Apr 21, 2016 at 5:53 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Also have a recovery /tug strap with you so if you do get stuck you can be pulled out . Another is taking a shovel and old used floor mats , semi truck mud flaps . The mud flaps can be placed in front of or behind the tires to allow for better traction
  6. Apr 21, 2016 at 5:54 PM
    skootx
    skootx Well-Known Member
    Erie, CO
    2014 Tacoma TRD Off Road Double Cab Short Bed
    Icon Stage 1 Shocks & coils Deaver AAL Light Racing UCA's PAC SNI-35 line output converters, miniDSP, Rockford Fosgate R600X5, Rockford Fosgate Punch P3 P3SD210, Helix Blue B62C speakers, HELIX Blue B5X 5 speakers G4 Elite Fold A Cover Rear Diff Breather Relocation
    Air down and you should be good, just don't get cocky and dig yourself into a hole.
    US Marine likes this.
  7. Apr 21, 2016 at 5:55 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Air down to no less than 8PSI - drive slow and steady with momentum and do not do donuts.
  8. Apr 21, 2016 at 5:57 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    On sand the tread pattern isn't that important. In fact an aggressive mud tire is more of a disadvantage that ordinary street tires.
  9. Apr 21, 2016 at 5:58 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    Mmmmmmm some may disagree...
  10. Apr 21, 2016 at 5:58 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    If you don't have a locker or limited slip rear basically an open diff you can do this trick ......
    Engage you e -brake a couple clicks , this will create enough friction it will send equal power to both axles . This is commonly called a poor man's locker . Just remember once you've regained foward momentum to disengage the e brake
    12TRDTacoma, ian2016 and Frankmig[OP] like this.
  11. Apr 21, 2016 at 5:59 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    Doesn't that ruin the brake?
    US Marine[QUOTED] likes this.
  12. Apr 21, 2016 at 6:01 PM
    koditten
    Kirk
    Central Michigan
    You are only doing that long enough to get unstuck.
    12TRDTacoma likes this.
  13. Apr 21, 2016 at 6:01 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Not if used just long to get your forward momentum going then disengage the e brake
    DustStorm4x4[QUOTED] likes this.
  14. Apr 21, 2016 at 6:04 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    ^ .......... This !!!!!
  15. Apr 21, 2016 at 6:05 PM
    koditten
    Kirk
    Central Michigan
    What year truck is this? Can you turn off the traction control?
  16. Apr 21, 2016 at 6:08 PM
    Marshall R
    Marshall
    none
    The best mud tires are narrow "pizza cutters" with stiff sidewalls that will cut through the mud and get to solid ground. For sand you want a much wider tire that can keep you on top of the sand. I know some guys use paddle type tires for sand racing. But those aren't mud tires. For general use a wide, tire with an all terrain or even street tires work better than a true mud tire which tends to just dig into sand.
  17. Apr 21, 2016 at 6:10 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    What I found that works awesome in the sand are BFG All Terrains and again aired down to no less than 8psi
    Frankmig[OP] likes this.
  18. Apr 21, 2016 at 6:12 PM
    Large
    Large Red
    And who are they? What he's saying is true.
    monsterkx2fiddy likes this.
  19. Apr 21, 2016 at 6:15 PM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    Glue a ring of flip-flops around the tires and you should be OK.
  20. Apr 21, 2016 at 6:25 PM
    FreddyFlintrock
    FreddyFlintrock Well-Known Member
    Spent 1978 summer vacation on Ocracoke and dad drove our '69 T-bird on the beach with airing down. Yep, got stuck a bunch (usually at the beach entrances), but got a lot further than I ever expected in that heavy car with street tires. A Taco with ground clearance, 4wd and aired down LE2's should be ok.
    bobamoo and Frankmig[OP] like this.
