OEM Tonneau Cover Ease of Removal
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hank_Mille, Nov 27, 2015.
  1. Nov 27, 2015 at 8:22 AM
    Hank_Mille
    Hank_Mille [OP] Well-Known Member
    PNW
    2016 Tacoma Limited
    Just in case it need to come off for ease of hauling stuff in the bed (e.g., motorcycle) - how hard is it to completely remove and reinstall the EOM Toyota tonneau cover?
  2. Nov 27, 2015 at 9:19 AM
    Shellshock
    Iowa
    Very easy. There is a bolt in the front passenger side you have to remove (it's a NHTSA requirement since its OEM) then just pull the releases and fold it up. Only takes a minute or two.
  3. Nov 27, 2015 at 9:30 AM
    Hank_Mille
    PNW
    2016 Tacoma Limited
    Thanks Shellshock!
    :thumbsup:
  4. Nov 30, 2015 at 3:43 PM
    drlocke
    drlocke Active Member
    What if I want to completely remove it and all install hardware? I heard that the rails are cut during the installation of the pins.
    Thanks!
  5. Nov 30, 2015 at 4:57 PM
    Wraith600
    Wraith600 Well-Known Member
    2016 AC TRD OR Quicksand
    That's true. There are pins that are still there which can be removed but your bed is cut to accommodate them.
  6. Nov 30, 2015 at 5:27 PM
    drlocke
    Thanks! Was close to buying a truck which I really like (inferno DCSB Sport) but I want a cap, not a cover - especially if the cover destroys the bedrails.
