OEM Tonneau Cover - Where to buy?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CaliTaco18, Feb 10, 2018.
  1. Feb 12, 2020 at 9:19 PM
    #321
    HLTaco
    HLTaco Well-Known Member
    Huy
    NorCal
    2020 Tacoma Off-Road 4x4
    Looking for a Tonneau in the Sacramento area.
  2. Feb 17, 2020 at 1:14 PM
    #322
    Dravyss
    Dravyss Well-Known Member
    Nick
    Kentuckiana
    2020 Sport 4x4 6MT
  3. Feb 17, 2020 at 2:40 PM
    #323
    Yeti Spaghetti
    Yeti Spaghetti Well-Known Member
    PA
    2018 Cement Tacoma Double Cab TRD Off-Road 4x4
    Looking to get rid of my factory in the next few weeks. Also will he selling the KB Voodoo bars. Likely going to be just buying new bed side rails but if someone has some in good condition would consider that. Located in Las Vegas.
  4. Feb 17, 2020 at 6:23 PM
    #324
    Danielon21
    Danielon21 Well-Known Member
    Kansas
    2019 super white Tacoma TRD Sport 4x4 dcsb
    Looking to buy a oem tonneau cover for 19 Tacoma short bed in or around Wichita Ks.
    willing to drive some!
  5. Feb 17, 2020 at 6:31 PM
    #325
    Kcm10883
    Kcm10883 Well-Known Member
    2019 Cement DC TRD Off Road
    buyer backed out OEM cover available in northern NJ came of '19 DBSB with 13K miles
  6. Feb 18, 2020 at 11:52 AM
    #326
    Papirafa
    Papirafa New Member
    Rafael
    tacoma trd short bed
    Is it still available
  7. Feb 18, 2020 at 11:55 AM
    #327
    Papirafa
    Papirafa New Member
    Rafael
    Where did you get it at
  8. Feb 23, 2020 at 1:51 PM
    #328
    medic1pc
    medic1pc New Member
    2019 Tacoma Calvary blue
  9. Feb 29, 2020 at 8:59 PM
    #329
    JaysTRDsport
    JaysTRDsport Well-Known Member
    AJ
    2020 Tacoma Trd sport 4x4 6spd manual
    Toyo off road tires
    I want a oem factory Tacoma long Bed cover Toyota parts Dept says I can’t get one on my 2020 Tacoma so if anyone is selling one I only have seen short bed 4 door ones I need access cab long bed one I am in northern Califorina
  10. Mar 2, 2020 at 11:15 PM
    #330
    javihh
    javihh New Member
    Javier
    2020 Khaki Tacoma TRD Sport
    I’m Looking for an oem tonneau Cover for my 2020 Tacoma Trd. Does someone know if a 2018 cover will fit mine? Thanks
  11. Mar 2, 2020 at 11:51 PM
    #331
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    2016-2020 are the same, you just need to make sure you get one for a 5' or 6' box.
    Toyota Canada sells the OEM tonneau cover as an accessory that can be added after the fact. Toyota USA seems to only want to offer it as a factory option.
    If anyone is near the border and wants to hop over, here are the Canadian part numbers:
    PK3B1-35J5H - Cover, Tonneau (Short Box, 5')
    PK3B1-35J6H - Cover, Tonneau (Long Box, 6')
    When the parts catalog was first updated for the 2016, there were part numbers in there for the complete assembly (64910-04010 for 5', 64910-04020 for 6') but Toyota ended up not selling them as complete units (aside from the Canadian accessories).
    If you're not near Canada, here are the part numbers you need to order in the USA to get the tonneau cover:
    Short Box, 5':
    64901-09010 - Panel, Tonneau Cover Front
    64902-09010 - Panel, Tonneau Cover Center
    64903-09010 - Panel, Tonneau Cover Rear
    64904-04010 - Hinge, Tonneau Cover Front
    64905-04010 - Hinge, Tonneau Cover Rear
    66248-04070 - Cover, Bed Side RH
    66249-04070 - Cover, Bed Side LH
    Long Box, 6':
    64901-09020 - Panel, Tonneau Cover Front
    64902-09020 - Panel, Tonneau Cover Center
    64904-04020 - Hinge, Tonneau Cover Front
    64905-04020 - Hinge, Tonneau Cover Rear
    66248-04060 - Cover, Bed Side RH
    66249-04060 - Cover, Bed Side LH
    Short and Long Box:
    64949-04020 - Screw, Panel to Hinge (Qty: 24)
    64949-04070 - Screw, Panel to Hinge (Qty: 20)
    64915-04010 - Cap, Front Hinge RH
    64916-04010 - Cap, Front Hinge LH
    64917-04010 - Cap, Rear Hinge RH
    64918-04010 - Cap, Rear Hinge LH
    64949-04080 - Screw, Cap to Hinge (Qty: 8)
    64933-04010 - Pin, Tonneau Cover Front
    90148-A0006 - Screw, Front Pin (Qty: 2)
    69442-04010 - Striker, Tonneau Cover Side No.1 (Qty: 5)
    69442-04030 - Striker, Tonneau Cover Side No.2
    69415-04020 - Cover, Striker No.1 (Qty: 5)
    69415-04040 - Cover, Striker No.2
    64949-04010 - Screw, Striker (Qty: 12)
    64935-04010 - Bolt, Striker
    62541-04010 - Moulding, Trim RH
    62542-04010 - Moulding, Trim LH
    If you buy these parts online at a discount, you'll probably be right around $2100-2200 USD. Toyota Canada sells the cover kit for about $1050 USD.
    Use this information however you'd like.
    Jeff
  12. Mar 3, 2020 at 8:12 AM
    #332
    JaysTRDsport
    AJ
    Toyo off road tires
    Good to know Canada can get a new one I will look into that since I got a new truck & would prefer a new one as to a 2 year old one on a new truck
    Jeff Lange likes this.
  13. Mar 3, 2020 at 3:42 PM
    #333
    Panchovilla6192002
    Panchovilla6192002 Well-Known Member
    Arizona
    2019 Cavalry Blue TRD SPORT 4X4 DCSB MT 2003 Red ExtraCab MT 5 lug
    Skip oem and get aftermarket. Cheaper and some are better looking.
  14. Mar 3, 2020 at 3:59 PM
    #334
    JaysTRDsport
    AJ
    Toyo off road tires
    So I called Canada Toyota yep they can sell the oem factory kit to Canadians with a Canadian Vin# Tacoma & have to be in person to order it no shipping the cost of it was $1,400 Canadian dollars plus there taxes FYi. As well I called Toyota USA to complain to them how stupid they are for not selling to USA but to Canada was ok the lady didn’t even know Canada was Allowed to sell the oem factory complete kits but here in the USA no has to be ordered & put on truck at the factory only BS. Glad I was able to find one in good shape for my truck. I like the oem look & fit style for what I am going to use it for.
  15. Mar 3, 2020 at 4:23 PM
    #335
    NickTaco
    NickTaco Well-Known Member
    SF BayArea
    23' TRD OR DCLB 4X4 MGM
    wtb SF bar area.
  16. Mar 3, 2020 at 4:24 PM
    #336
    Jeff Lange
    Calgary, Canada
    You certainly don’t need a Canadian VIN to buy one in Canada. Any person could walk into any dealer and buy one easily enough.
    Shipping would be pricey to get it down to the US though.
  17. Mar 3, 2020 at 4:33 PM
    #337
    JaysTRDsport
    AJ
    Toyo off road tires
    I talked them this morning up there in the north he said he would sell it to me if I walked in just have to come in no shipping to the USA cost was $1,400 plus there taxes his computer shows not for USA market he couldn’t tell me if it was a different style but I am sure it’s the same style.so I got a good used one so will stick with that for now maybe if I go there on vacation maybe drop in & get a new one.
  18. Mar 3, 2020 at 4:59 PM
    #338
    Jeff Lange
    Calgary, Canada
    Toyota Canada often has their own accessories but in this case it is the same as the factory one available in the US.
    Jeff
  19. Mar 3, 2020 at 5:18 PM
    #339
    JaysTRDsport
    AJ
    Toyo off road tires
    Yes I know but Toyota really doesn’t want us to get one unless we get it from the factory & order it online instead buying a truck on a dealers lot & get one in the parts Dept. After the fact. But it’s ok for Canada just not us that’s BS.
  20. Mar 3, 2020 at 5:40 PM
    #340
    Jeff Lange
    Calgary, Canada
    Take solace in the fact that there a ton of accessories sold in the US that aren’t available here. Haha.
