Oem tonneau covers on 2021 Tacomas
Discussion in '3rd Gen. Tacomas (2016-2023)' started by zoo truck, Jan 16, 2021.
  1. Jan 16, 2021 at 11:02 AM
    zoo truck
    zoo truck [OP] Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Been stopping to look at least a couple dozen new 2021 tacos here at different dealers in recent weeks when passing by. Not a single one seen on the lot with a factory tonneau cover installed like i use to see on last years trucks. Just curious what gives...is there a shortage, or is now a dealer option if someone wants it?
  2. Jan 16, 2021 at 1:09 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    It's junk, you don't want one anyway. Believe me I have one. Leaks, fades and is to heavy. There a hell of a lot better covers put there.
    BeatnikFink, rickc5, martinh and 2 others like this.
  3. Jan 16, 2021 at 1:18 PM
    Gmarch49
    Gmarch49 Well-Known Member
    2020 Quicksand TRD OR
    I believe the parts for the OEM tonneau are hard to come by which is likely why you don't see as many.
    With that being said you can find a used one from someone on here or on Facebook groups/marketplace.
    With that also being said I got one from a member on here for cheap. The cover does it's job. I don't keep precious documents in my bed so the small amount of water that gets in doesn't bother me.
    CubanSammichPt2 and Bleep100 like this.
  4. Jan 16, 2021 at 2:22 PM
    mdh_us
    mdh_us Well-Known Member
    Right now you can only get the factory tonneau cover on Magnetic Gray and Army Green based on the Toyota build page.
  5. Jan 16, 2021 at 2:25 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    oem tonneau cover is expensive af as well
    Tacomaryan18 likes this.
  6. Jan 16, 2021 at 2:27 PM
    ctagz
    ctagz Well-Known Member
    Fountain Valley, CA
    2017 TRD Sport dcsb - Inferno
    I had OEM cover before buying my shell. As others have mentioned, it leaks but not a lot. If I was to go back to a cover, I might consider a Snuglid or Diamondback.
  7. Jan 16, 2021 at 2:41 PM
    Tacomaryan18
    Tacomaryan18 Well-Known Member
    18 Ltd Dbl SB super white
    My oem cover leaded like a sieve through the trifold gaskets. Toyota replaced under warranty and the new one “only” leaks around the sides which is a significant improvement. I wouldn’t expect it to be completely leak free. All in all though if I were starting all over again I wouldn’t bother with the oem cover. The cheap vinyl cover I had on my Tundra did a better job.
  8. Jan 16, 2021 at 2:57 PM
    ct2021
    ct2021 Member
    2021 Cement Tacoma ORD
    I just got a 21 ORD from a SE Toyota dealer and they only offered a soft cover Toyota tonneau and wanted 700 bucks for it. They wanted 1200 for an aftermarket hard cover. Ended up finding the lomax stance thread here and purchased through a member. Super pleased with it and got a great price relative to the above.
    Twize and Tacomaryan18 like this.
  9. Jan 16, 2021 at 7:08 PM
    IndyTac
    IndyTac Well-Known Member
    Indianapolis
    2019 TRD OR DCSB w/JBL
    Total Chaos bed stiffeners CaliRaised bed tie-downs CaliRaised 0-degree, bolt-on rock sliders Meso Customs Gas Hole JDM console and dash organizer Ceramic front tint Ceramic windshield coating Ziebart underbody and rust proofing Taco Garage Dashtop Multi-Mount (DMM) Black SR5 Grille Surround Swap Tacos4cheap Grille Badge Redarc Tow Pro Liberty Brake Controller Car Solutions Anytime Camera Mod TacoMods Radio Knobs Desert Does It Seat Jackers
    Get an aftermarket, not OEM. Aftermarket covers are cheaper and some allow full access to the bed, which the OEM doesn’t. Supremely disappointed in my OEM cover. The gaskets are trash and it leaks badly.
    Chew and Tacomaryan18 like this.
  10. Jan 16, 2021 at 8:22 PM
    Barrister
    Barrister Well-Known Member
    Dennis
    Mesa, Arizona
    2023 TRD Pro, Solar Octane, 6 speed Manual
    Predator Steps, OEM Tonneau
    Maybe it’s your market area but I got one on my 2021 Barcelona Red Metallic in Arizona.
  11. Jan 16, 2021 at 8:31 PM
    mdh_us
    I changed the ZIP code to 85226 and it let me add it to an OR in Barcelona Red. I tried a couple other colors and it let me add it. I wonder why they would make that option allowed on different colors based on a ZIP code. But if I use ZIP code 63028, it only lets me select the option on the colors I posted before.
  12. Jan 16, 2021 at 8:41 PM
    CubanSammichPt2
    CubanSammichPt2 Well-Known Member
    2020 TRDOR Tacoma
    Stock
    I got the oem one used for $150. Hardware and all. Just look for the right deal.
    Mine has been great, very little leak.
    zoo truck[OP] likes this.
  13. Jan 17, 2021 at 7:34 AM
    zoo truck
    None
    Didn't ask if junk or not. I've have the factory tonneau cover on my 2020 truck for nearly a year now, and its fine...no leaks either. Yeah, i'll agree its heavy, but seems to be made well.
    When i looked at 2020 trucks on dealer lots last year a number came with tonneau covers. This year i stop by dealers i've not seen any.
    RedWings44 likes this.
  14. Jan 17, 2021 at 7:42 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Love my factory one as well. Plus it stores nicely in the garage when I don't want to run it.
    zoo truck[QUOTED][OP] likes this.
  15. Jan 17, 2021 at 8:40 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
  16. Jan 17, 2021 at 11:49 AM
    zoo truck
    None
    I probably would of bought a 4runner or some suv if i needed to put some type of top like that on it. The factory tonneau cover works well for my needs....do wish it were lighter though.
  17. Jan 17, 2021 at 1:44 PM
    GOTSAND?18
    stock
    Does a 4 runner roof fold down in under 1 minute . :);)
    howmuch4onerib likes this.
  18. Jan 18, 2021 at 6:58 AM
    zoo truck
    None
    No but i'd wonder how that top would stand up long term to a 20'' heavy snowfall, or a serious ice storm.
  19. Jan 18, 2021 at 7:37 AM
    BroncoAZ
    BroncoAZ Well-Known Member
    Cape Cod, MA
    2021 WhiteTacoma TRD Offroad
    I looked at a black truck in 86004 that came with the OEM tonneau cover. I ended up buying one from a member here, so far so good. I had a Diamondback on my Raptor, it was awesome but cost me 4x what I paid for the OEM Toyota cover from a member here off his 2 month old truck.
  20. Jan 18, 2021 at 7:50 AM
    Westsideott
    Westsideott Well-Known Member
    Ottawa, ON
    2020 DCSB OR
    I have the factory hardcover. It is a bit heavy for reinstall and only opens 2/3 of bed but otherwise it's robust and water resistant enough for me
