OEM Tonneau Lock Mod
Discussion in '3rd Gen. Tacomas (2016-2023)' started by pushgears, May 26, 2021.
  1. May 26, 2021 at 3:08 AM
    pushgears
    pushgears [OP] Well-Known Member
    2021 OR DCSB MT
    Has anyone come up with a way to lock the OEM Tonneau Cover? I have the locking tailgate, however someone could theoretically snake a wire hanger under the tonneau's rear lip and pop the release handle.
    Was thinking of installing the loop side of a lock hasp on the underside of the rear edge of the tonneau and cable locking it to the rear tie down cleats/D-rings. Thoughts?
  2. May 26, 2021 at 5:00 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Someone could also theoretically pry the dang thing open with a crow bar! I think there is really only so much you can do here brother; if they want to get past your tonneau cover, they will get past it.
    Bleep100 likes this.
  3. May 26, 2021 at 5:29 AM
    HVLA
    HVLA Well-Known Member
    Idaho
    2020 Voodoo Blue OR DCSB 6MT
    Post a video of you using a coat hanger to open it. It wont be as easy as you think.
    pushgears[OP] and mrtonyd like this.
  4. May 26, 2021 at 5:32 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    It only keeps an honest person out. If someone wants in the back or if they want to take your whole truck, they will do what they need to do to get it.
  5. May 26, 2021 at 5:38 AM
    PeterK2003
    PeterK2003 Member
    I accidentally locked my tailgate with the cover closed and the lock disabled in the tailgate. I thought it would be easy to grab the handle with a wire...an hour later I finally got it. It also appeared that if you lifted/pried the cover up it made it very difficult to pull the handle. I am not sure if that was an intentional design or just a side effect of having pressure on the latch.
    pushgears[OP] likes this.
