OEM Toyota Bed Step
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rraiderr, Nov 12, 2022.
  1. Nov 12, 2022 at 6:52 PM
    Rraiderr
    Rraiderr [OP] Well-Known Member
    Great White North
    2017 Tacoma TRD off road
    Working now a list
    I ordered the OEM Toyota bed step.
    Has anyone installed this themselves?
    Any tips?
    Did you use the OEM setting or move yours out more?
    Thanks
  2. Nov 12, 2022 at 6:54 PM
    Tacospike
    Two Trucks
    Follow the directions…?
    Do they adjust?
    Mark77 likes this.
  3. Nov 12, 2022 at 6:56 PM
    Rraiderr
    Great White North
    Working now a list
    I watched the installation video, looks like the 2, 66 foot pound bolts are hard to get to.
    Yes, you can adjust how far it sticks out.
    Tacospike likes this.
  4. Nov 12, 2022 at 7:13 PM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    Installed myself, used the recommended position per the instructions. Isn't too tough as long as you have a decent ratchet with some leverage.
  5. Nov 12, 2022 at 8:21 PM
    carlk
    carlk Well-Known Member
    Virginia
    2022 MGM SR 2.7 Access Cab Utility Pkg
    I installed the bed step right after I bought my truck. The installation was pretty straight forward. I located the step at recommended setting. I didn't think it needed to be out more. Watch a couple of you tubes and you'll be a pro.
    The hardest part of the installation for me was the very last step, getting the 3 littles screws to engage into the nut plates in the step. See 3:40 of the attached video. The guy in the video had no problem, but I did. The video shows the installation on a 2nd gen, it's exactly the same on the 3rd gen.
    Edit: I just thought of one tip. The 3 little screws are only torqued to about 6 ft-lbs so may want to put some Locktite on them.
    https://www.youtube.com/watch?v=MDeWF3IiyZs
  6. Nov 12, 2022 at 8:27 PM
    DVR
    DVR Well-Known Member
    SC
    23 TRD Pro
    I had no issues installing on my 2021 tacoma.
    Just installed one from amp on my F250.
    The oem toyota one is said to be made by amp.
    I'll be adding one to my incoming 2023 tacoma as soon as it arrives.
    There are some more reasonably priced ones on Amazon. I'm going to stick with the oem version.
    TexasWhiteIce likes this.
  7. Nov 12, 2022 at 8:30 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    It's been awhile since I installed mine, but I don't recall it being difficult to do. Well worth the effort though, I use it all the time.
  8. Nov 12, 2022 at 8:36 PM
    d0ugh0ck
    d0ugh0ck Well-Known Member
    NJ
    Mine came with the step already attached all the way extended. I like it there. The bolts you have to remove are cranked down. I didn't have a bar to put on the ratchet, doable though.
  9. Nov 12, 2022 at 8:41 PM
    DVR
    SC
    23 TRD Pro
    The only option for mounting is the step pad inward or outward.
  10. Nov 12, 2022 at 8:42 PM
    d0ugh0ck
    NJ
    It's extended outward
  11. Nov 12, 2022 at 9:01 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Use mine all the time too - just today to hop in to fold up the Bakflip so I could load some pipe at Home Depot.
  12. Nov 12, 2022 at 9:12 PM
    stan23
    stan23 Well-Known Member
    stan
    Santa Clara, CA
    2025 DCSB TRD Sport 4x4
    I installed mine on my 2016 and now 2022 truck. Super simple and one of those accessories that comes in super handy when you use it!
  13. Nov 13, 2022 at 6:14 AM
    grandpawmoses
    grandpawmoses Dirty Old Man
    David
    2021 Tacoma Limited Nightshade
    No money
    I installed mine, took less than an hour. I used red Loctite on the bolt threads.
    OEM Toyota stuff doesn't come with instructions but I've attached them here. Youtube videos are good but I like to see the actual instructions too.
    gr8-wrx likes this.
  14. Nov 13, 2022 at 6:44 AM
    wayne0
    wayne0 Well-Known Member
    I installed mine easily. The bumper bolts were super tight though. It took some grunt to loosen them.
  15. Nov 13, 2022 at 6:45 AM
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Falken Rubitrek AT 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    I installed mine, no problems. Top bolts hard to reach, but I was able to get it done. Did not realize the little screws had torque rating… mine are tight. I use it all the time!
  16. Nov 17, 2022 at 8:33 PM
    Rraiderr
    Great White North
    Working now a list
    Thanks much for the help everyone.
  17. Nov 18, 2022 at 7:53 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Doesn't weathertech make a bed step that you insert in the hitch receiver?
  18. Nov 18, 2022 at 8:49 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Yup, but it’s blocked if you drop the tailgate. OEM step works with the tailgate up or down.
  19. Jul 16, 2025 at 9:02 PM
    Mr. Dallas
    Mr. Dallas Active Member
    Hubbard
    Texas
    2023 SR5 SX AC 4WD V6,'99 Tacoma SR5 5 sp. MT Xtracab; '06 Scion xB; '02 MR2 Spyder; '13 RAV4 LE
    You don't need the bed step if the tailgate is up: you just step on the bumper and climb up, so I don't really understand the hitch mounted type. I installed the OEM bed step on my truck and love it. I'm not the handiest guy in the world but it wasn't that hard. I used my big Gorilla bar extendo lug wrench to crank those frame bolts off, no problem. I use it all the time to get in the bed when the tailgate is down.
  20. Jul 16, 2025 at 9:10 PM
    2021SR5V64WD
    When you start pushing 70 you'll understand why stepping on the bumper and swinging over the tailgate isn't the best way to go....
