OEM Toyota Tacoma TRD Off-road Bilstein Shocks on SR5?
Discussion in 'Suspension' started by phoenixpiole, Feb 2, 2019.
  1. Feb 2, 2019 at 2:42 PM
    phoenixpiole
    phoenixpiole [OP] Well-Known Member
    2018 Tacoma DCSB SR5
    Hi All,
    I’m looking into possibly purchasing some Toyota Tacoma OEM new take off (16-19) TRD Off-road front struts and Bilstein rear shocks and front coil springs for my 2018 Taco SR5, would yall foresee there being any issue with the stock leaf springs that came with my truck? I discovered from a Toyota part number search they’re different on the TRD OR trucks, I’m guessing they’re bulkier.
    I’m taking off the 2” ARB OME Kit with EL095R leafs because it vibes like crazy due to angles which I’ve tried to measure and fix without any success which is why I want to use the stock leaf springs that came with the truck to avoid interfering with driveline angles.
    My SR5 is 4x2 as well so the drive shaft is longer than the 4x4 driveshafts making angles even more difficult to adjust.
