OEM Toyota XM Module 86180-0E011
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Jeremy M., May 29, 2016.
  1. May 29, 2016 at 1:57 PM
    Jeremy M.
    Jeremy M. [OP] Well-Known Member
    Fort Drum, NY
    13 DCSB TRD Off Road
    I am selling an OEM Toyota xm module, satellite antenna not included. I am asking $100.
  2. Jun 8, 2016 at 6:40 AM
    Jeremy M.
    Fort Drum, NY
    Bump, still for sale
  3. Jun 8, 2016 at 7:39 AM
    rrod
    rrod Well-Known Member
    Rob
    2013 Tacoma Double Cab TRD Sport
    ICON Coilover & Boss Ext strut & Dakars rear. JBA UCA
    is this the whole radio interface or??
    I have a 2013 DBL Cab it has the radio / phone unit, what would I need other than a fin?
    ** I see this is just an add on module, do you know if it will work with the stock radio/ phone unit? Thanks
  4. Jun 8, 2016 at 10:08 AM
    Jeremy M.
    Fort Drum, NY
    This module works with the OEM toyota radio, all it requires is an antenna the unit is plug and play with your stock radio.
  5. Jun 8, 2016 at 10:31 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    The important thing, is that it has the cable, which is around $60 alone.
    So many of these XM modules are missing this essential cable.
  6. Jun 8, 2016 at 11:10 AM
    TRD2010SpeedwayBlue
    TRD2010SpeedwayBlue Well-Known Member
    Brandon
    2010 Speedway Blue TRD Offroad
    so is this the module that enables the xm on my radio? i have the antenna on the roof the color matched one. and was told i need some harness or something and than subscription in order to use xm
  7. Jun 8, 2016 at 11:16 AM
    Jeremy M.
    Fort Drum, NY
    This is the module you need, and a subscription of course.
  8. Jun 8, 2016 at 11:22 AM
    rrod
    Rob
    If I had the damn shark fin, this would be SOLD! If you have the fin BUY IT! :hattip:
  9. Jun 8, 2016 at 11:26 AM
    tomwil
    East Coast USA
    2014 Reg Cab 4x4
  10. Jun 8, 2016 at 11:52 AM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    No, you don't have the right radio. 2012 and previous had the XM module built into the non-touch screen radio, not attached to it.
    That module bolts under and to this style touch screen radio that has XM capabilities and the proper plugs. I have the Canadian version module plugged into this 2014 radio and installed in a 2012. It was not plug and play. Adapters were required.
    https://www.tacomaworld.com/threads/oem-2014-tacoma-navigation-radio.298745/
    There are many threads on here for various year installs and adaptations. Here's a list of threads.
    https://www.tacomaworld.com/threads...tion-retrofit-diy-w-info-part-numbers.318616/
  11. Jun 8, 2016 at 6:29 PM
    Jeremy M.
    Fort Drum, NY
    Thanks for the knowledge bomb
  12. Jun 10, 2016 at 7:31 AM
    Jeremy M.
    Fort Drum, NY
  13. Jun 10, 2016 at 8:58 AM
    taczilla
    Marc
    2016 RAM Rebel
    No problem.
  14. Jun 11, 2016 at 5:38 AM
    Jeremy M.
    Fort Drum, NY
  15. Jun 12, 2016 at 11:51 AM
    Jeremy M.
    Fort Drum, NY
  16. Jun 12, 2016 at 7:06 PM
    taczilla
    Marc
    2016 RAM Rebel
    You called it.
    You're welcome.
