OEM TRD Grill?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco11179, Apr 12, 2022.
  1. Apr 12, 2022 at 12:22 PM
    Taco11179
    Taco11179 [OP] Well-Known Member
    Jake
    2022 Tacoma SR5 Double Cab 6 foot bed
    I have a 22 SR5, I'm interested in replacing the grill with that semi-circle type grill that the TRD's have. Is that possible? Would I have to have the sensors in the logo re-calibrated?
  2. Apr 12, 2022 at 12:28 PM
    davepatrick
    davepatrick Member
    Dave
    Gilbert, AZ
    22 TRD Sport - Gray
    lifted, wheels/tires/ black badges and other small stuff
    You can easily replace the existing grill with an OEM TRD Pro grill, but if the sensors move location in relation to the grill you might need to have them recalibrated. You could always order the grill through the dealership and have them install it, if you want to avoid worrying about that. But it will cost you...
  3. Apr 12, 2022 at 12:30 PM
    oogielaflick
    oogielaflick Well-Known Member
    Keith
    2019 Toyota Tacoma TRD Sport 4-door; Prvious 23 year owner of 1996 Tacoma
    Quicksand with hood protector, color matching decals on tailgate latch, mudflaps, glovebox, and tailgate hitch cover.
    Oh gosh, there are a ton of threads on trd pro grills! But, to answer your question, it is easily possible, as the grills are interchangeable. You would not have to recalibrate, but you may have to put a thin washer in the top screw of the sensor on the grill, so that it adjusts the angle of the sensor to make up for the lower height since in the trd pro grills the sensor is lower. I won;t go any further, as there are plenty of posts out there on this.
  4. Apr 12, 2022 at 12:34 PM
    Taco11179
    Jake
  5. Apr 12, 2022 at 12:47 PM
    oogielaflick
    Keith
    Gosh no! The one with the chrome trim is on a SR5 and there is a grill that is just like it, which is on the plain SR. It is all black including the trim around the grill. I actually like this all black grill, as shown in your first pic, except for without the chrome trim. It is not a bad looking grill. The second grill pic is on the TRD Sport, commonly referred to as the "chicken wire" grill because that is what it looks like! HATED IT! Look at my profile pic beside this comment, click on it, and you will see a TRD Pro grill that i bought from MadHornets.com for just over $100 including the sensor cover, back in 2019. The TRD pro grill has the letters T O Y O T A across the front of the grill and not the toyota round logo. That is what differentiates it from the other grills. By the way, swapping out the grills is very easy as long as you area careful and can be done in about 20-30 minutes.
  6. Apr 12, 2022 at 7:07 PM
    22 Sport
    22 Sport Well-Known Member
    Central California
    2022 TRD Sport 4WD Long Bed
    I just took mine off my brand new 2022 TRD Sport and put on a Pro Style Grille. I took it off at 180 miles, it's brand new still. I'll sell it to you reasonable if you are near Fresno, CA.
