OEM TRD Oil Filter Rattle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Leomania, Jul 24, 2021.
  1. Jul 24, 2021 at 3:39 PM
    Leomania
    Leomania [OP] Well-Known Member
    Leo
    2011 Tacoma TRD Sport DCLB v6 4x4
    All stock, baby!
    I had an order going at McGeorge and they had the TRD oil filter (PTR43-00080) at a significant discount and I added a couple to my cart. They arrived today and I noticed that the filter internals are rattle around. Same situation on both, so just curious for those that have used these filters in the past whether that's normal. Never noticed this in any oil filter I've ever handled.
    I haven't changed the oil in the truck since I bought it (only 1K miles on the last oil change) so I don't know if the regular OEM filter does that as well. Probably normal but seemed best to check.
  2. Jul 24, 2021 at 4:42 PM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    Kolter45 likes this.
  3. Jul 25, 2021 at 7:31 AM
    centralcoastbuc
    centralcoastbuc Active Member
    2015 Tacoma TRD Sport 4x4
    I guess that explains the great deal!
    Hobbs likes this.
  4. Jul 25, 2021 at 7:42 AM
    steelcity2
    steelcity2 Well-Known Member
    Pittsburgh Pa
    2013 MGM DCSB TRD sport
    Bilsteins 5100's all 4 corners 1 inch rear spacer
    What is the difference between a stock oem filter and a TRD Pro? Appearance or internals ?
  5. Jul 25, 2021 at 8:06 AM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    No it doesn’t. If it came from McGeorge it’s legit OEM.
  6. Jul 25, 2021 at 9:29 AM
    TacoTuesday1
    FL
    discounting $17 to $12 + shipping for a small oil filter is not a great deal
    OEM is like $6
    maybe one is fleece and one is paper inside or something, when all should have been fleece to begin with, as other manufacturers have done for over 20 years.
    Or maybe it's a metal baffle inside. I don't know. Never cut one apart. Probably won't.
    It is awfully small, despite room for larger. Other cars all use bigger ones.
    I'm not sure if that's just their way of increasing oil capacity, or if added filtration media is actually needed.
    For example, if oil capacity is 4L on a vehicle and you put a big oil filter, it might bump that to 4.3L or more.
    That's more of a problem on small turbo engines that don't fit much oil, because too little, and it sludes.
    Taco though has no turbo, and is a low power ~220hp N/A motor at about 5.5qt
  7. Jul 25, 2021 at 9:42 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Then it's a "legit OEM" filter with something loose inside that they discounted the price on. Just checked a box of qty 10 90915-YZZD3 OEM filters and none of them rattle.
  8. Jul 25, 2021 at 10:12 AM
    davidstacoma
    David
    NC
    You do realize yours is a different part number and a different filter than the OPs, right?
    https://toyotaparts.mcgeorgetoyota....vbWEmeT0yMDE5JnQ9dHJkLXBybyZlPTMtNWwtdjYtZ2Fz
    Here’s a cut apart of the TRD filter:
    https://bobistheoilguy.com/forums/threads/toyota-trd-filter-cut-open.135143/#post-1943117
    Could be the sound when shaken is just the metal screen against the inner column, but understand why the OP asks the question.
    Bottom line- someone whose actually used the TRD filters or has one on hand could answer the OPs question . It’s not gonna be you or me.
    I’ve bought many things from McGeorge Toyota online, they are a reputable dealership in Virginia and have some of the best prices online. If there is anything wrong with a part they sell it could be returned.
  9. Jul 25, 2021 at 11:04 AM
    OffroadToy
    Yeah.. i realize mines different... that's why i posted my part number. Bottom line- i've used alot of different oil filters over the last 50 years and none had something loose inside... just saying. Does that make it defective... i couldn't say.
    davidstacoma[QUOTED] likes this.
  10. Jul 25, 2021 at 11:09 AM
    davidstacoma
    David
    NC
    same here. see my edit I’m thinking it could be that metal screen against the inner column, quite different than filters I’ve used before, so would be good to hear from someone else who has a TRD filter.
    OffroadToy[QUOTED] likes this.
  11. Jul 25, 2021 at 1:35 PM
    jbrnigan
    Midwest
    OP, save yourself the (potential) grief, and return the TRD filters that rattle to the seller. Spin on oil filters contain a number of different "moving" parts; by-pass valves, anti-drain back and anti-siphon valves (depending on filter specs), but not "loose" parts. I would NEVER install a spin on oil filter, from any mfr that "rattled".
    Knute, wmgeorge and steelcity2 like this.
  12. Jul 25, 2021 at 10:52 PM
    Leomania
    Leo
    All stock, baby!
    I've got a message into McGeorge about them. I'll report back with their response.
  13. Jul 26, 2021 at 8:30 AM
    Leomania
    Leo
    All stock, baby!
    Got a reply from McGeorge:
    Come to think of it, the sound isn't unlike those "widgets" inside cans of Guinness that release nitrogen when you pop one open. Oil is brown... Guinness is brown... hmmm... :cheers:
    Thanks all for the discussion.
    steelcity2 likes this.
  14. Jul 27, 2021 at 12:27 AM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    Don't most modern oil filters have pressure relief valves? I'm still kind of curious why this particular type is rattling.
    I say you cut it open and let us know. :D
  15. Jul 27, 2021 at 6:01 AM
    blu92in99
    blu92in99 Hates everyone, equally
    Justin
    Elk Grove, Ca
    The TRD oil filter is just a relabelled K&N oil filter. Another marketing gimmick for Toyota to pad their TRD catalog with, in order to separate fools from their money.
    steelcity2[QUOTED] likes this.
