OEM TRD PRO upper control arms
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TRD_dee151, Dec 2, 2024.
  1. Dec 2, 2024 at 11:10 AM
    TRD_dee151
    TRD_dee151 [OP] Well-Known Member
    Oregon
    2023 TACOMA TRD OFF ROAD V6 Celestial Silver
    TRD Pro Grille 5% Window Tint WeatherTech Side Window Deflectors Cali Raised Catalytic Converter Shield Leather Seat Covers JDMCAR Center Console Organizer JDMCAR Glove Box Organizer High Flying smoke Sequential Turn Signal Tactical Sun Visor Molle Panel BumperShellz Armored Coated OEM TRD PRO Skid Plate Alpharex LUXX-Series LED Tail Lights Alpha-Black 255/70/17 Falken AT/4 all stock no lift. 17" Method 305nv Double Black with 0 offset Diamondback Switchback Baja Designs Squadron-R Fog Light
    I am looking at OEM TRD Upper Control Arms
    Part number PT901-35230
    Will these work with aftermarket struts & shocks
    Or will they give me problems
  2. Dec 2, 2024 at 11:17 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Chew likes this.
  3. Dec 2, 2024 at 12:43 PM
    TRD_dee151
    Oregon
    I have watch both of these videos in the pass already.
    i ordered Elka 2.5 IFP preset from factory at 2.5 inch
    I am assuming these TRD UCA are for at least 2 inch or less, But there is no information out there I can find
  4. Dec 2, 2024 at 12:47 PM
    gudujarlson
    Minnesota
    What do you mean by, “these TRD UCA are for at least 2 inch or less”? That doesn’t make any sense to me. The TRD Pro UCAs are not intended to be used with any aftermarket parts, but they might not cause any problems.
  5. Dec 2, 2024 at 1:09 PM
    TRD_dee151
    Oregon
    the TRD pro only have a lift of 2 inches, so what I was saying is are these UCA made for a 2inch lift NO more then 2 inches.
    allot of aftermarket UCA will work with 1inch to 3 inches of lift.
  6. Dec 2, 2024 at 1:11 PM
    gudujarlson
    Minnesota
    I just realized that the shocks you are referring to have a diameter of 2.5”. Since this requires 3” diameter coil springs, you might run into UCA-coil clearance issues.
    When I bought my King 2.5 kit, I remember headstrong telling me I needed the SPC UCAs because the stock UCAs would not clear the coil springs. My memory might be wrong.
    Additionally, with a 2.5” lift, you might need high caster UCAs in order to get your alignment in spec.
    YMMV.
  7. Dec 2, 2024 at 1:18 PM
    gudujarlson
    Minnesota
    I’m not sure where you are getting the idea the TRD Pro has a 2” lift or that aftermarket UCAs are made for a specific lift height.
    There are “high caster” UCAs that are intended to help obtain good alignment in combination with a lift. The TRD Pro UCAs are not high caster UCAs AFAIK.
  8. Dec 2, 2024 at 1:30 PM
    FunknNasty
    FunknNasty Well-Known Member
    San Jose
    2022 Pro
    The trd upper control arms are standard on the 22 and 23 pros. Pros come with 2.5 foxes, and yes the springs fit but just barely.
    The trd upper control arm ball joint geometry differs slightly from oem uca, supposedly to help with binding at near or full droop.
    And, I think I’d be more concerned with your wheels and tires clearing the trd uca than anything else.
    TRD_dee151[OP] and gudujarlson like this.
  9. Dec 2, 2024 at 8:06 PM
    Broheim
    Broheim Well-Known Member
    San Antonio, TX
    2023 TRD Pro
    OP
    You are correct in assuming that they should work if everything is replicated. If westcott lift works, 3” coils, and offset and tire size is close/same then your approach makes sense.
    Your thinking is as good as some of the AFAIK’s, mights and maybes.
    Let us know what you find out.
  10. Dec 2, 2024 at 8:29 PM
    soggyBottom
    soggyBottom Well-Known Member
    Sounds like sneak oil to me. Save yourself $500 and buy some total chaos UCAs with heim joints.
  11. Dec 2, 2024 at 8:42 PM
    MGMDesertTaco
    Elevate and Camburg make some really neat anodized colored uca's.
    TRD_dee151[OP] likes this.
  12. Dec 2, 2024 at 8:51 PM
    TRD_dee151
    Oregon
    Those UCA are ugly, ill just stick with Elevate billet aluminum UCA, yes they cost allot but they also look bad ass.
  13. Dec 2, 2024 at 8:53 PM
    TRD_dee151
    Oregon
    I have had my eyes on Elevate for a long time, even over JBA UCA, the billet aluminum ones.
    MGMDesertTaco[QUOTED] likes this.
  14. Dec 3, 2024 at 10:24 AM
    Mach
    Mach Well-Known Member
    2022 Lunar Rock DCLB TRD Off-Road
    The TRD UCAs stick further out than stock so are more likely to rub wide tires. This then requires more megative offset wheels or spacers and then you start running into the tires rubbing the body mount. Make sure you are going down the right rabbit hole before purchase.
