OEM trifold hard tonneau cover adjustment
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kashing, Oct 13, 2022.
  1. Oct 13, 2022 at 8:05 AM
    kashing
    kashing [OP] Well-Known Member
    David
    '22 MGM TRD OR
    Is there any adjustment at the final latch, the one closest to the tailgate? Mine closes but then I need to put some weight (my whole body) over each latch to get it to fully lock in. I don't see any screws or anything, but I could be missing something.
  2. Oct 13, 2022 at 8:14 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    There is shims under latches, cover side. That's the only adjustability. You have to slam it of push it like you are. You could add another shim.
  3. Oct 13, 2022 at 8:21 AM
    kashing
    David
    '22 MGM TRD OR
    Great, thanks! Is it easy to access the location to put another shim in?
  4. Oct 13, 2022 at 8:47 AM
    na8rboy
    WI
    Open cover one fold , unbolt latch on cover add shim/washers. When I had mine, I removed factory shim so it would pull down tighter.
  5. Oct 13, 2022 at 1:50 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I ordered my truck with the factory tonneau cover. Idk who installed it but it close's, and seals like a glove. Doesn't require any effort except gravity to latch it closed. Just be sure the tail gate is down before latching the cover.
  6. Oct 14, 2022 at 2:53 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Mine too, super tight, no leaks, looks like new after 4 years no issues. I close the tailgate and then the cover, followed with a little push on the rear corners until you hear a clicking sound.
    zoo truck[QUOTED] likes this.
  7. Oct 14, 2022 at 7:18 AM
    zoo truck
    None
    I don't even have to push down to hear the cover click. Just closing it does that. We had a rain storm last night, i did my grocery shopping this morning, and inside the bed was perfectly dry.
  8. Oct 14, 2022 at 7:20 AM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    for me, if i close the tonneau first, then tailgate, it closes fully. if i have tailgate up, then i have to push each side.
  9. Oct 17, 2022 at 6:11 AM
    kashing
    David
    '22 MGM TRD OR
    I unscrewed it and put a nylon washer under each side, it's still very tight, but a little bit easier to snap closed.
  10. Oct 17, 2022 at 7:05 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I have always heard folks say that there are "two clicks" to close and properly latch the OEM cover. Mine must be adjusted perfectly as all I have to do is let it go a few inches above the rails and it latches completely and seals right up. And BTW, love my OEM cover too. Damn thing is an absolute beast and tough as nails.
    VaToy likes this.
  11. Oct 17, 2022 at 8:15 AM
    rolled93slc
    rolled93slc Well-Known Member
    Jerry
    Lynchburg VA
    16 Tacoma TRD Sport DCSB MGM
    Make sure then bed rail tie downs aren't getting in the way. They will make it very hard to get the second click of the latch. Found this out from experience. Mine were too far forward and there are little bump stops, for when you flip it over.
    MuchoTacoLoco and CanadaToy like this.
