OEM tube running board installation
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kelly, Mar 6, 2010.
  1. Mar 6, 2010 at 3:21 PM
    Kelly
    Kelly [OP] New Member
    Colorada
    2010 TRD
    Could anyone please let me know how easy (or hard) it is to install the OEM tube running boards on a 2010 Tacoma? Will there be a need to drill or do they bolt to existing holes?
    Thank you
  2. Mar 6, 2010 at 3:33 PM
    Canadian Max
    Canadian Max Yamaha
    In the Garage
    2010 TRD 4X4
    2010 TRD Sport 4 door Speedway Blue 4" Nerf Bars Vent visors Weathertechs Mats Hella 500 HID Mod Bull Bar Devil Horns Eclipse AVN 726E Energy Speakers
    They bolt up to existing holes covered by threaded plastic caps ;)
  3. Mar 6, 2010 at 3:57 PM
    ShadowFalken
    ShadowFalken Well-Known Member
    Jim
    Maryland
    10 Off Road
    Raptor stainless bars, Wet Okole covers, RollBak bed cover, PopNLock, Redline hood struts, XM radio factory kit
    Butter. Pay attention to side and position markings for all brackets and tubes and you will not have any trouble. Pay attention to torque values so you do not stress bolts or threads in body, just in case you want to remove them later. Tighter is not better.
    I suggest anti-sieze on the bolts and I also put a light coat of "Rite-Stuff" on the contact areas to protect the paint. (Under the bracket where it bolts to the body. Like a rubber gasket from a can) Get everything in place and finger tight before you start locking everything down. Helps prevent stress and helps with good alignment. Recheck the bolts in 3-5K miles to verify they are still secure.
  4. Mar 6, 2010 at 4:00 PM
    JayJay
    JayJay Well-Known Member
    Pacific Northwest
    08'Taco.DC,SR5.TRD. Off Road,Manual 6Spd.
    3 inch lift Rev Tek Bilstien shocks .Westin crome side nerf bars (steps) Toyo 285-16" , HID High/Low 4300k ,yellow fogs 3000k, Lear cap 100 XQ , Thule Tracker 2 roof rack , Bed Rug bed liner ....
    What he said , simple....... ^^^^^^^^^ Enjoy !!!!!
  5. Mar 12, 2010 at 7:04 AM
    Kelly
    Colorada
    2010 TRD
    Thanks a lot gang! Those running boards are on their way and I can wait to install them.
