OEM versus aftermarket fluids.
Discussion in 'General Tacoma Talk' started by zanemoseley, Apr 28, 2024.
  1. Apr 28, 2024 at 8:01 AM
    zanemoseley
    zanemoseley [OP] Member
    Getting ready to get all new fluids in my 2021 TRD OR that has 62k. I got 2 cases of OEM transmission fluid for $120 but looking at the diff and transfer case fluid I'm getting sticker shock. 6 quarts of OEM diff fluid is about $210 versus $68 for Mobil1. Then a quart of transfer fluid is $75. What do you guys think, stick with OEM or save the cash and go aftermarket?
  2. Apr 28, 2024 at 8:04 AM
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    If you look at the fluid certifications they usually meet or exceed original manufacturer requirements
    nothing wrong with Mobil 1
  3. Apr 28, 2024 at 8:14 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I don’t run OEM fluid on anything but coolant. If I had an automatic I’d probably use it there too. Otherwise, I don’t see the point to sticking with only OEM fluid.
  4. Apr 28, 2024 at 8:20 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Toyota doesn't make their own fluids. They have other manufacturers put their fluids in Toyota bottles with Toyota's logo on them and charge you more for them.
  5. Apr 28, 2024 at 8:21 AM
    Archimedes
    Archimedes Demanufacturer
    Outside the stupid part of Vermont
    23 DCSB TRD OR MGM
    Full-on degenerate heavy metal banjo music
    Even Walmart Supertech branded fluids are Warren / Exxon / Penz etc for good replacements. Don't be afraid to use them.
    Wulf likes this.
  6. Apr 28, 2024 at 8:22 AM
    Squirt
    Squirt Samsung Aficionado!
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back with a 3in Speedys Snap resonator. J&L catch can. AMP Powersteps
    The only one I know I'd stick with OEM fluids would be the trans. Everything else I'd use high quality fluid brands. I always liked the using the Mobil 1 synthetics.
  7. Apr 28, 2024 at 8:26 AM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Similar to everyone above, only fluids I go OEM on is coolant and fluid for an Automatic transmission. Otherwise I don't even take the recommended fluids as more than a suggested viscosity
  8. Apr 28, 2024 at 2:43 PM
    zanemoseley
    Great I'll go with Mobil1 for the diffs and transfer. Thanks for the help.
  9. Apr 28, 2024 at 7:19 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    Those of you sticking with OEM coolant, curious what the reasoning is. I'm coming upon 6 years with mine and am thinking of changing it.
  10. Apr 28, 2024 at 7:33 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    There's a lot of confusion and conflicting information on what the exact equivalent of "WS" is.
    Until I get that figured out, I'm doing my trans with OEM. Everything else is easy to find generic equivalents.
    Junkhead likes this.
  11. Apr 28, 2024 at 7:39 PM
    BLtheP
    Plano, TX
    My only reasoning would be because I don’t really trust that the aftermarket equivalents for OEM coolants are exactly what they’re supposed to be. There are so many different types of coolants and colors to them across all makes and models that I’d rather just use the OEM stuff because I know what to get since it’s already in there.
    Also, normally other coolants aren’t usually cheaper, or at least not by much, especially considering how infrequently coolant is messed with. So another reason to just buy the OEM stuff.
    4x4junkie[QUOTED] likes this.
  12. Apr 28, 2024 at 7:39 PM
    Squirt
    Ben
    Don't forget OEM Blinker Fluid! Don't need to have issues with that system!
  13. Apr 28, 2024 at 7:43 PM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    I home brew my own with a grain still , two quarts of balsamic toluene, and a rudimentary rotary kiln.
  14. Apr 29, 2024 at 6:35 AM
    joba27n
    Nolan
    Alberta
    My reasoning behind the coolant is that for the cost usually being similar or sometimes cheaper than aftermarket along with different chemistry coolants don't tend to play nicely with other I just play it safe with coolant. I don't see much if any benefits to switching coolant unless you run the old green stuff
    4x4junkie likes this.
  15. May 19, 2024 at 4:03 PM
    9pm
    9pm Well-Known Member
    Just kidding!!
  16. May 19, 2024 at 4:16 PM
    Squirt
    Ben
    :rofl::rofl::rofl:
  17. May 25, 2024 at 12:44 PM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Oem fluids are a joke just rebranded valvoline fluids that Toyota uses .
  18. May 25, 2024 at 12:48 PM
    Clinch Mountain Preacher
    Clinch Mountain Preacher Serpent handler
    3rd gen AC SR5 4x4
    I'm not a pro toyota tech, but I only go out of my way for the oem Toyota brand ATF and engine coolant.
  19. May 25, 2024 at 2:09 PM
    thedudeabides22
    thedudeabides22 Well-Known Member
    2024 Tacoma 4x4 TRD Offroad
    OEM fluids for everything but motor oil here (mobil 1 xp).
  20. May 25, 2024 at 8:42 PM
    I-Give-Up
    I-Give-Up Well-Known Member
    West Phoenix, AZ
    2023 Ice Cap Tacoma TRD
    Meso spare fuse holder. Aluminum gas cap holder. Genuine Toyota bed lights. Bed molle racks. Ammo case storage under hood. In-bed spare tire. Automatic underhood lights. Gooey glurp on frame.
    Toyota fluids made by Valvoline? That's an interesting assertion. Do you have some evidence for that? I wouldn't be surprised to learn that the OEM fluids are made by Pentosin.
    joba27n likes this.
