OEM versus aftermarket fluids.
Discussion in 'General Tacoma Talk' started by zanemoseley, Apr 28, 2024.
  1. May 26, 2024 at 3:55 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Mobil and Idemitsu are makers of Toyota fluids.
  2. May 26, 2024 at 4:36 AM
    bfonic
    bfonic Well-Known Member
    2023tacoma
    I used to get mobil synthetic gear oil by the drum at work. It worked out to about $5 a quart. If I had a spare $75 for a quart, it would be scotch whisky. lol
  3. May 27, 2024 at 9:21 AM
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    Stick to Toyota genuine pink long life coolant, and transfer case gear oil.
  4. May 27, 2024 at 2:43 PM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    The dealer doesn’t even use the oem transfer case fluid ..maybe the coolant but it shows it makes no difference in fluid just intervals when changing… using oem specific fluids is just a waste of money … just stick with what is equivalent to it.. it literally says it in the Toyota manual ok to use .
