OEM vs after market engine air filters
Discussion in 'Technical Chat' started by Jetty Rat, Jul 2, 2015.
  1. Jul 2, 2015 at 7:23 PM
    Jetty Rat
    Jetty Rat [OP] Well-Known Member
    South Texas
    2006 Tacoma Prerunner SR5 TRD Offroad
    After reading the excellent post showing the OEM vs after market oil filters, I have to ask. Has anyone one done a similar test with engine air filters? Are the OEM air filters the best quality or are there better after market alternatives?
    Thanks!
  2. Jul 2, 2015 at 7:26 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Stick with the OEM air filter. All the others won't change or do anything additional. So don't waste your money
  3. Jul 2, 2015 at 7:28 PM
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Diode Dynamics SL2 Pro LED Bulbs. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit. Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander GPS. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Struts and Shocks. KPOffroad Alignment Cam Upgrade Kit. Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME 886x Coil Springs. OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    I run stock. I had the TRD/AFE CAI. Dint see any gains. I've seen a few others on here do power tests with no gains. I run the OEM air and oil filters.
  4. Jul 2, 2015 at 7:30 PM
    Jetty Rat
    South Texas
    I am running an OEM filter currently. I'm not really looking for power gains, just the best protection available.
  5. Jul 2, 2015 at 9:04 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  6. Sep 8, 2015 at 8:52 AM
    bluesttape
    bluesttape Well-Known Member
    Denver
    '14 TRD Sport DCSB
    Debadged 3in Lift KO2s 275/70/17 OEM Stock Rims w/TRD Center Caps TRD Cap-Back Exhaust Avid Light Bar A.R.E. CX Cap OEM Nerf Bars OEM Rack on Cab Thule Rack on Cap WeatherTech Floor-liners WeatherTech Vent Visor CoverKing Seat Covers Chicco Keyfit 30 :-) Clifford 5806x Alarm & Remote Start LED Replaced (dome,map,flasher, reverse, & parking) Salex Organizer in Glove Box & Center Console Fully Tinted 12in ClearBra
    Bump...
    I too simply want the best protection. I like the idea of more power, but I'll worry that about once I pay the truck off. Lol.
  7. Sep 8, 2015 at 8:54 AM
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    In my personal experience...all my Tacomas always were happier with OEM Oil Filters. I'd stick to OEM.
  8. Sep 8, 2015 at 8:58 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    NAPA and or Wix gold.
  9. Sep 9, 2015 at 12:57 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I was using Wix my local dealer closed now I switched to Toyota Just bought a case of Air Filters and Oil filters should last about a year.
  10. Sep 9, 2015 at 3:15 AM
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR
    I use OEM. I tried a TRD drop in filter and it came with the taco tick. I walked back inside and returned it. Put the stock filter back in and my motor is quite. Wtf
  11. Sep 9, 2015 at 6:07 AM
    bluesttape
    Denver
    '14 TRD Sport DCSB
    Where is the best place to purchase OEM air filter online?
  12. Sep 10, 2015 at 8:36 AM
    wake100
    wake100 Well-Known Member
    Syracuse, NY
    2021 AG DCLB off road 4x4
    Uptop roof rack, cali raised light bar, diamondback tonneau
  13. Sep 10, 2015 at 8:53 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I have an AFE.....and that's only because I can clean it and keep using it. I've had the same one for about 8 years.
  14. Aug 31, 2022 at 11:14 AM
    MegaHurts777
    MegaHurts777 Well-Known Member
    Jacob
    ID
    2019 Tacoma TRD Off-Road (MT)
    Does anyone actually know what the micron and flow rating is for any of these filters? I sadly tried looking but can't seem to find the info.
    Filters in question>>
    Denso / Toyota OEM | 17801-07020
    WIX | WA10085
    ACDelco A3397C Gold
    AFE
    K&N
    (insert filter I didn't think of)
    I don't trust my butt dyno and visual inspection of the intake won't tell one much in the way of how well 1 filters air over another (with the exception of extreme cases).
    What loose information I do have is that Denso and Wix are kind of neck in neck.
    They are both cellulose filters and based on tests in other vehicles seem to be about the same.
    Anyway, just curious in case someone has that info as I'm just looking for hard facts/like to compare stuff.
