OEMAudioPlus Dual Amp Issue
Discussion in 'Audio & Video' started by MSQuicksandTacoma, Nov 5, 2020.
  1. Nov 5, 2020 at 11:28 AM
    MSQuicksandTacoma
    MSQuicksandTacoma [OP] Well-Known Member
    Harris
    2017 Quicksand Tacoma TRD Off-Road
    I ordered the reference 500 system with dual subs from OEMAudioPlus. I installed the speakers back in July, and waited to install the amp until the subs came in. The subs are coming in today. I finally got around to installing the amp last night, and when I hooked it all up, there was no sound coming from the right tweeter and the front right door speaker. I double checked all connections and they were fine. Does anyone know why this is happening?
  2. Nov 5, 2020 at 11:32 AM
    toyotahenry
    toyotahenry N/A
    Houston, Texas
    2021 TRD OFF ROAD 4X4 ARMY GREEN
    Something might have got shorted thats not visible from the naked eye.
  3. Nov 5, 2020 at 1:19 PM
    MSQuicksandTacoma
    Harris
    Do you think its the amp?
  4. Nov 5, 2020 at 7:16 PM
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
    When you install the amp is when you run the T-Harness. It may not be an amplifier issue, it could be something in the harness that’s causing you to lose front right.
    You should be able to verify signal on each pair with a multimeter on the amplifier input connector. I would start there.
    toyotahenry likes this.
  5. Nov 8, 2020 at 10:40 AM
    MSQuicksandTacoma
    Harris
    How do you do this?
  6. Nov 8, 2020 at 11:23 AM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    Can you give us a basic rundown of how you wired your system? For example I left all the factory wiring in place and and ran new wires for all my channels. If you spliced into anything that’s always a good place to start. Are your doors also amplified?
  7. Nov 8, 2020 at 12:43 PM
    dolbytone
    South Carolina
    09 TRD Off Road
    Make a pigtail that you can insert the wires into the terminals of the connector you need to meter. Insert one end of the pigtail wires into the connector pins you want to take a reading from, use the other end to connect to your multimeter probes.
    Play a 1KHz tone on your stereo at mid-low volume and check your multimeter for VAC. You should see the voltage generated by the tone through the speaker out of the factory stereo. You will need to know/find out which pins are used for each speaker out. Move your wires to different pins of the connector to meter all of your stereo outputs and verify all are working. You should get reasonably similar readings on all channels. The next step in finding out what to do will be determined by what you find by performing this procedure.
    Here is a picture of my whip and a connector I have lying around wired to my multimeter.
  8. Nov 8, 2020 at 6:01 PM
    MSQuicksandTacoma
    Harris
    I didn't splice anything, and the OEMAudioPlus system allows you to keep factory wiring. I disconnected the speaker input wire and plugged it into a wire running to the amp, and then plugged another wire running from the amp to my speaker input on the back of my stock radio. I didn't run any wires on the right side of the car, so I couldn't have bumped a wire. I ran the power cable through the drivers side firewall nipple.
